Question about NetGear DG834G Router
Netgear DG834g routing issues
I have recently bought a Netgear dg834g and configured to be the access point of my home office. I have three computers attached to it: one apple macbook, one apple macmini and an acer aspireone.
Each computer works perfectly and I can surf the net.
The problem is that after a while, the router stops routing traffic in the local network so I cannot see the other computer. I cannot ping them...
If I restart the router, everything starts working again... for a while...
What can it be?
Thanks in advance
  • 3 more comments
  • stefano_forn Jul 04, 2009
    Hi, thanks for the answer. I actually already upgraded the firmware to the latest available, and I am using DHCP with reserved addresses. I would be reluctant to use static IPs, since I want to solve the issue with the router, not give up on the services I paid for.... :(
    I'll be happy to rate you the max, if we do progress, be sure!
    sre
    Thanks a lot for your answer.
    I have already upgraded to the latest fw available and configured DHCP with reserved addresses :(
    I would be reluctant to use static addresses as I want it does what I paid for ...
    Be sure, I'll be happy to rate your help at max as we do progress. Thanks a lot for replying.
  • stefano_forn Jul 05, 2009
    I am not sure I understand the
    I am not sure I understand the question: this is a WIFI ADSL modem router... I am using it for what it is supposed to do...
    ste
  • stefano_forn Jul 06, 2009
    Hi anandg27,
    thanks for your help. Can you please explain to my why it should help? Currently, everything works no problem if I restart the router. After a while, it looks like the router stops correctly routing internal IPs. What does this has to do with the router/AP configuration?
    Thanks a lot in advance.
    Ste
  • 1,272 Answers
Upgrade the firmware on the router. If possible assign static IPs on the computers.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
  • Anand Gupta
    Anand Gupta Jul 05, 2009
    Is there any specific reason if you have configured this router to work as an access point. Does this router works when you use it as an actual router.
  • Anand Gupta
    Anand Gupta Jul 06, 2009
    Well, then it seems that you are using this router as an actual router and not as an access point. I would suggest you to reset the router and then reconfigure it.
    Reset using the steps below:
    At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. Press it and hold it from 30 seconds and after 30 seconds without releasing the reset button take out the power cable from the router and wait for 20 seconds. After 20 seconds, without releasing the reset button plug the power cable back to the router and keep holding the reset button for another 30 seconds. Now, release the button and take out the power cable wait for 5 seconds then plug it back.
    Now reconfigure the router and check if that helps.
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
I have two netgear routers and wondered if i can make them work together to extend my wireless internet range e.g. using them as repeaters (rather than having only one turned on depending on the area of...
i dont believe you can do such thing but you could run two routers and log onto each individually. Just like your at home using the laptop and you go to a friends 20 miles away and you take your laptop and it will recognize his wireless allowing access.
Jan 06, 2011 | NetGear DG834G Router
Sky router wi fi failed bought used netgeae DG834G on ebay can not get internet access
hi,
Clicking on the following download link will download the manual, about 7.5mb in size , it contains all of the infromation you require to get your netgear up and running.
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Regards
GeWiz.
Dec 07, 2009 | NetGear DG834G Router
POWER FAILED WHILE UPGRADEING NETGEAR DG834G
Plug in the power cord. Push and hold the reset button for about minute. This should do it. If not contact netgear at 1-888-638-4327.
Jan 24, 2009 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
NetGear DG834G Router Logo
308 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
