I have a sony mini disc deck and I want to try and get my laptop to accept the audio, to enable me to move it into itunes. Please help!!
  • 509 Answers
What Minidisc player do you have? Does it have a USB connection or just audio connections? The Sony Sonic Stage software should allow you to store the Minidisc music on your laptop - you might have to make a CD of it first, THEN covert the CD into iTunes.
Posted on Sep 01, 2009
Sony minidisc will not eject discs
This could be a worn out loader. I've had bad luck with push in to load decks since I push them in too hard and wear them out, I migrated to tray loaders for this reason (I have a JA50ES and a JA20ES) which like other high end MD decks have a try which opens up to accept the disc.
The mehanisms wear out and are not worth fixing. I paid a pro $350 to fix a JA3ES a few years back and it only worked for a short time. I'd simply try to find a replacement deck rather than spend too much time or trouble on it. The 510 and 520 are great decks but getting very long in the tooth like me...
Apr 22, 2014 | Sony MDS-JE520 Mini Disc Player
Recorded mini discs no sound on playback
They should both have the same standard format, but my best guess is you may have recorded one MD in one of the sony longer formats which the Tecnics can't read. The normal MD Decks may not have the old sony extended paly format and even some of the Sony high end decks don't have all of the formats. Sony tried several says to give more recording timje on a disc before migrating to the HiMN standard as an example.
Mar 14, 2014 | Audio Players & Recorders
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Sony stereo
Check speaker wiring on the back for shorts, if okay! the problem is in the audio output ic in the unit.
Apr 22, 2012 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
Strange recording problem - no diagnostic messages
Sounds like the servo is shot on the deck that moves the laser. MDS JE520 is a nice early deck 1998-1999 vintage, so it's had a great run and I'd look for another on eBay or at a "hamfest" swap & shop for parts.
Mar 26, 2010 | Sony MDS-JE520 Mini Disc Player
I have a problem, minidisc deck mds je 480
HELLO
C13 is what is called a "Protection Error". This normally happens because the if you look on the bottom edge of the minidisc itself you will see what looks like a plastic strip or tab at the bottom left.
Pull it to the left for it show fully and this will enable you to record onto the disc. Move it right, and this will PREVENT recording from taking place.
If you have the unit connected up by the optical lead and you're trying to record the audio from a DVD unit, the MD deck is probably telling you what you are trying to record is copy protected. I never use the optical lead, just hook it up by good quality interconnects and the recording you get is superb. Both DVD & CD audio!
All The Best! :-)
Jul 23, 2009 | Sony Audio Players & Recorders
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
Copying video from a mini DV cassette
When i connected DCR-HC40 to my Laptop to download the pictures from Handycam,i cannot download the pictures.IN my laptop i have a Vista Software but it is not supporting picture package 1.0 version,can u give me solution for this how to download the software for Vista
Oct 02, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
75 people viewed this question
 Grubhead
Grubhead
