Kenmore top loader blues
Use a screwdriver to remove the screws holding down the control panel,then swing it upwards.
Pop the s clips in the rear and remove the lid switch disconnect.
Tip the case forward and remove it.You will now be able to repair the
washer!
The lid must be closed for spin. The lid has a striker in it that
pushes against the lidswitch arm. This switch allows for spin IF the
lid is closed. The switch may have failed. Mechanically the striker may
be broken or the actuator arm may be broken.
here is a broken lid switch
You can test the switch. If you have a meter. If not you can
simply bypass this switch. In my left hand here is the lid switch male
plug which I have removed from the lid switch harness. If I wanted to i
could simply place a jumper between the 2 outside wires and the washer
would spin.
Do not leave it bypassed if you have small children or braindead brother in laws.
A 3 piece drive coupling
NOTE: newer models have the screw hidden
Here is a view of the washer with the case removed.
To get to the broken coupling
remove the pump first then
the motor,both are held
together with quick clips.
pictured here is a broken drive coupling.
Line up the new part and replace
the motor, pump, and
case in reverse order.
NOTE:
This looks hard but if you take
your time it is easy enough to save you big bucks!
My friend RM made a 44 second movie on this subject.
Click here to see it
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
