Question about Maytag MAH8700A Front Load Washer
Washing Machine wont power up
I plug in my Maytag MAH8700A Front Loading Washing Machine into a confirmed working outlet, no lights or sounds come on, whether I turn the knob or press any buttons. Please help!
My roommate and I are very capable and have almost any tool we may need, so if you would like to walk us through it over the phone we would be greatly appreciative.
478 338 2106
    President:
  • Maytag Master
  • 662 Answers
Check whether the power plug of machine is good, connections, fuse, main wire, etc. All good, then try below:
Plug off the wall socket. Open up the machine. Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. This normally works.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Posted on Jun 17, 2010
My Electrolux EWF 8556 Front Loading washer wont Start
Hi I would check the plug to see if the wires have come loose or the fuse is gone in the plug this can happen at any time and its the last place you always look, the plug looks fine but
Nov 15, 2017 | Washing Machines
Washer door latch will not open. there is no power to the machine at all. outlet works.
If you remove the bottom panel in front you can reach up on the right hand side to near the middle of the door you will feel a tab coming out of the door lock switch. Pull down and the door should release.
Oct 25, 2010 | Maytag MAH8700A Front Load Washer
Error code ''suds'' on maytag front loading washer
Press Chime and Extra rinse keys for three seconds or until the control beeps. You are now in service mode and your machine should say a new error code. Depending on what that code is, you might be able to reset your machine by unplugging it, and replugging it in. if your codes are now clear, try running machine on spin only or rinse cycle. DO NOT add more soap!!! If this corrects your problem, try running a load with out soap. You may have a lot of extra soap in your machine.
Mar 20, 2010 | Maytag MAH8700A Front Load Washer
How to restart an interrupted front loading washer
try unpugging for a minute and then plugging it back in to reset cpu board, if this doesnt work make sure power is getting to outlet, easiest way i know is with night light in same outlet, if u have a light trhen u have a cpu problem some of these units came with a five year warranty on the control board, u would have to read your warranty in your manual to find out.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
No power at all
ok first if you look in the dispenser drawer may have to push the tab and remove the drawer there is like a yellow pull tab will unlock the door second if your sure their is power to the washer the look at the control panel for burned resistor on the control bd and let me know if your serial number ends in ga through gx or ja through jn
Jan 30, 2008 | Maytag MAH8700A Front Load Washer
Washer
Sounds like you need to replace the door switch
Jun 23, 2007 | Maytag MAH8700A Front Load Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
