Question about Samsung Audio Players & Recorders
When TV is selected, I get an echo
Samsung HT_BD1250
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
• Try pressing the MODE button on the remote control and set the unit to MATRIX. You can see this on the front panel of the unit.
• Or try setting up the AV SYNC of the unit to 0ms delay.
Posted on Jul 03, 2009
WHILE RUNNING BLUE RAY PLAYER FOR ABOUT 3 MIN IT SHUTS DOWN
More than likely something getting very hot in that period of time. Especially if you have to wait awhile before it restarts. If this is the case, locate the part that is getting very hot and replace it.
Nov 07, 2015 | Samsung HT-BD1250 Theater System
How do you Hook up a samsung ht-bd 1250 to a net gear wnc2001wireless router
In case you want to RTFM:
http://www.manualslib.com/manual/144113/Samsung-Ht-Bd1250.html?page=30#manual
If you are connecting a cable from the player to one of the LAN ports on the back of your router, then you shouldn't have to do any configuration.
If you're connecting wirelessly, then you'll need a Samsung wireless adapter. Your model doesn't have internal wireless, and it won't take any other wireless adapter but the Samsung WIS09ABGN adapter. It also looks like there is only one USB port, so if you plug in the wireless adapter, you won't be able to plug in USB storage devices.
Our Samsung Blu-Ray player had some trouble connecting, and what I discovered is that it couldn't deal with a network SSID that contained anything but letters, and couldn't deal with a network security (WEP/WPA) key code/password that had anything but numbers and letters. A good WPA key should have at least one special character (punctuaion, &, etc.), but you might have to simplify the key for your Samsung.
So here are some steps to connect wirelessly:
1) Write down your router's SSID, which might also be called "network ID" or "wireless network" or something similar. (If you don't know this, you can log into your router to see it, or check to see what wireless network your computer is connected to; the name of that network is the SSID.
2) Write down the WPA key to your network. If you don't know it, you'll have log in to your router and look on the "security" or "wireless security" tab. It might be called "WEP key" or "WPA passkey" or "network password" or whatever.
3) Check both of those for hypens, ampersands, etc. If there is a special character in either the SSID or key, you'll have to log in to your router to change it.
Once your SSID and key have only numbers and letters, you're ready for a manual install.
It's a bunch of steps, and here they are from the manual:
http://www.manualslib.com/manual/144113/Samsung-Ht-Bd1250.html?page=51#manual
Dec 17, 2014 | Samsung Computers & Internet
I am on laptop to watch Netflix. How do I get started streaming? Tells me to enter an activation code. Where?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Samsung Ht-bd1250 5.1 Channel Home Theater...
Stutters, locks up during Blue ray playback
How long does it take to lock up?
If it takes 20 minutes...
If the unit has a fan, make sure that it is working.
Unhook the player and put it in the freezer for half an hour...
Then try it again... If it takes longer than 20 minutes.
then you know it is an overheating problem...
Jun 01, 2011 | Samsung HT-BD1250 Theater System
Just hooked it up and only 2 front speakers work . all speakers work when switched around any tips
You don't mention having followed the manual so...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-BD1250T-Home-Theater-Systems-manual/id/23336ag421/t/2/
Did the speaker setup test tones work on all channels?
Mar 30, 2011 | Samsung HT-BD1250 Theater System
What does FanChck mean on my samsung HT-Z320? How to I fix it?
I had the same problem with my Samsung HT-BD1250. In my case the fan did not run at any time! As a safety precaution, to prevent overheating, when the fan is malfunctioning the receiver powers off. I simply opened up the receiver and discovered that the fan was not even connected! I just plugged it in and.....Voila! Works like a charm. Be warned though that if your unit is still under warranty, opening it up will likely void the warranty.
Feb 07, 2010 | Samsung HT-Z310T Theater System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
Running my tv sound though the home theater
Depending on the type of connection your TV has, you would either connect RCA type cables or an HDMI cable from your TV to the Samsung unit. If you hook up and still don't get any sound, check you cabling ti ensure it is plugged in the correct way. If you don't have the manual, you can go to the following URL to get one:
http://www.samsung.com/ca/consumer/detail/support.do?group=audiovideo&type=hometheatre&subtype=hometheatresystems&model_cd=HT-BD1250T/XAC&mode=C
Jul 10, 2009 | JVC THG31 Theater System
Fan check
From what I can gather the problem is caused by a faulty sensor. I don't know where the sensor is yet. But I have eliminated everything else associated with the fan which is the fan lol.
I have taken the fan out of my HT-Z510 and hooked it up to my computer and it worked flawlessly.. I am awaiting an email from Samsung as we speak. I will keep you posted
Dec 27, 2008 | Samsung HT-Z310T Theater System
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Aug 01, 2008 | Televison & Video
206 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
