Question about Dell InspironTM 1501 Notebook
Xp is working and you can see logon screen in a
Xp is working and you can see logon screen in a well lit room but it seams the back light in not any clues to this problem thanks [Dell pp21L laptop]
  • Dell Master
  • 32,281 Answers
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 28, 2009
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
Logon screen will not accept any passwords.
hi,follow these steps :
1.turn it on
2.press F8
3.select safe mode or safe mode with networking if you need internet
4.here you can save,change ,delete accounts so on
5.when you done restart and you can log on with your settings.
Jan 09, 2010 | Dell Inspiron 8100 Notebook
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Dell E1705...Same problem...lights on boot up
If the screen goes dark after BIOS, there is a software conflict - either a driver or screen resolution was set incorrectly. a couple of ideas to solve:
boot from disk, or another hard drive - if this works, it confirms the software conflict - which would mean having to re-install the OS.
Jun 24, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
I have a Dell pp21L laptop.i forget its PW.how to open it
You would have to all Dell Technical Support , they would give you a default password. There is no way to remove the password by removing any battery or jumper on a laptop.
Thanks
proton
Apr 04, 2009 | Dell Latitude C400 Notebook
Black screen after WinXP boot, same in Safe Mode
Pressing F8 during startup, just after the BIOS screen, will give you the
safe mode menu, including the option to create a '%windir%/ntbtlog.txt'
bootlog file
or you can try to restore xp:
Description of the Windows XP Recovery Console:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314058
Mar 15, 2009 | Dell Inspiron™ 600M PC Notebook
LOGON PROCESS INITIALIZATION FAILURE
Assuming you are using Windows XP. There's some file corrupt or missing when you start your pc. If you have floopy disk you can boot disk, it not your can insert your Windows XP installer and then you can repair you OS.
Jun 26, 2008 | HP Pavilion dv6000z Notebook
Dell B130 Laptop Boot Problem
if battery is new and functioning properly(battery) please boot in safe mode by pressing F8 during os starup. and logon as an administrator.
if nothing works out try reinstalling operating system it will solve the problem else update me the ststus.
Feb 26, 2008 | Dell Inspiron B130 Notebook
Video out
try to reconnect your cable of your projector just make sure that well-fitted on the port and screws are intact then to try to restart your laptop.ok?
if still doesn't work.just let me know!!
Jan 16, 2008 | Dell Latitude D600 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell InspironTM 1501 Notebook Logo
75 people viewed this question
Alun Cox
