Question about Acer Aspire 6920 Notebook PC
My Acer pc monitor sais "no signal" - Acer Aspire 6920 Notebook PC
    Sniper:
  • 162 Answers
Then you want to be checked your monitorand cpu by mechanic it can be a problem of your motherboard or monitor nothing other region
Posted on Jun 28, 2009
Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Dec 07, 2011 | Acer Computers & Internet
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
Acer monitor says no signal, then goes blank. Is
We are using the same monitor type.. humm it's good that i already had experience with it. No drivers needed to install this monitor, check the connection to the PC and to the monitor, make sure they are inserted properly. Sometimes when you put on the PC first and then power on the Monitor causes this problem. The best recommend resolution is 1440X990, good luck..
May 15, 2010 | Acer AL1916W 19" LCD Monitor
Acer al1922 monitor no signal:
If it does the same with other PC then you need to open it up and first thing to look for are bad caps in the power supply, see example of failed monitors due to bad caps, transistors, transformers, lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, and always replace with good quality caps such as PANASONIC FM or FC series from DIGIKEY.
Mar 23, 2010 | Acer AL1916W 19" LCD Monitor
My hotkeys work but no video signal out to external monitor. How do I get this to work?
What exactly are you using as the external monitor? Is it just a normal LCD monitor, CRT monitor or LCD tv/Plasma tv? Also get me the make and model of the same.
Please provide this info so that I can help you with your problem.
Sai.
Mar 05, 2010 | Sony VAIO PCG-K23 Notebook
We are getting a No Signal on our monitor,
it should be motherboard problem.
try to check it nearby service centers
are you able to hear any beep sounds
pp
Nov 21, 2009 | Acer Aspire L100 PC Desktop
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Acer E380 monitor issues
the display signal is not coming from your pc check the RAM of your pc
Sep 17, 2008 | Acer Aspire™ T180 PC Desktop
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Acer Aspire 6920 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
