Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
Printer eventually loses connection...
Like to get some advice from anyone.
Problem: I'm losing connectivity from wireless laptops to Dlink DPR-1260 wireless printer server.
Equipment:
Sonicwall TZ150W wireless firewall / router (not-bridged to LAN)
HP ML150 Server
HP LaserJet 2420 Printer
Dlink DPR-1260
Scenario:
HP Server and Printer are connected to LAN, and internal users can print OK via the 192.168.0.x network
My customer needs to have sales people attach to wireless network which is in a different subnet from the LAN, and cannot be bridge through the Sonicwall TZ150. These users connect OK via WPA-PSK via 172.16.0.x network. They must also share the "one" HP 2420 Printer and print wireless.
I purchased the Dlink DPR-1260 and intially was not able to get it connected via AD-HOC, so I elected to go with Infrastructure. It's joined to the router and MAC address is registered.
I then added printers in various XP and Vista laptops. Initally it makes a connection and allows to print. Eventually the print queues in laptop will lose connection and not appear available. I'll eventually have to unplug the print server, and sometime reconfigure via the print setup wizard in order to get the laptops to see it.
Some users even notice that when they reboot their laptops the print job will kick out.
Also, I have to have a cat5 cable plugged into one of the Dlink's port or else it will lose it's connect.
I'm wondering if I should try an hammer out the AD-HOC problem and if that would work in a encrypted WPA environment.
I appreciate any feedback from you guys. I'm not finding any thing out there on the search pages.
Thanks,
LDG
  • 1 more comment
  • AtulMori Nov 08, 2007
    I recently starting having a similar problem. Print server was working fine for about 3 months. For last one week, it loses connectivity everytime I print a document. I have to again unplug the print server and then I can print one more document. It is quite annoying. Appreciate if anyone knows an answer to this.
    ABM
  • Anonymous Dec 28, 2007
    I have a simular problem only my connectivity to the print server lasts about 15 minutes then I have to unplug it. Whats up?
  • Gabriel-ccs Apr 25, 2008
    It seems the internal web server shutts down (no access to the server settings page, printer leds are off, won't print anything) when something happens. In my case turning on the wireless antenna in my laptop equipped with Vista triggers that, even when the wireless capability setting at DPR-1260 is turned off. I have it near a linksys 'N' wireless router.
    I have a few months with the wireless in my laptop off, but yesterday it started again having the same problem. I keep thinking it is all about some weird internet packet, maybe from someone else's wirless/Vista equipped laptop nearby shutting down my server. Apparently nobody knows why...
Solution to loosing connection:
Assign a static IP-address to the DPR-1260 through it's own webinterface. The static IP should be OUTSIDE the DHCP IP Address Range of your DHCP server (in most cases your router). Thus: do not reserve a IP address via your DHCP server.
Posted on Jul 07, 2008
If I power off my HP printer, the DPR 1260 loses connectivity with the printer. I have to reinstall using the USB connection from the printer to the PC, then DON'T POWER DOWN THE PRINTER, & then move the USB to the server & reinstall. The printer will work as long as the power to the printer stays on.
Posted on Jan 21, 2008
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Posted on Jan 06, 2008
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: Can't reset the dpr-1260
Ok try to reset it again, try this steps use a pen then while the power is ON to your router press and hold the reset button for 30 seconds then after that release the reset button and power OFF the router for 10 seconds and then try to access the router setup page using the computer that is wired to it....
Posted on Nov 02, 2008
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
DLink DPR 1260 lost connection
Are the small printer icons lit up on the face of the PServer? Mine has recently started losing connectivity and simply unplugging the power and plugging it back in restores full function. Still looking for the reason it just started doing it though..
Mar 17, 2009 | D-Link Computers & Internet
Hi!!! How do I set up wireless printing? I have an HP1022 printer...
You should have your DSR 1260 connected via cable to your router. Open a browser. Go to http://dlink-xxxxx (xxxx=last 6 digits of your 1260's MAC address) or http://192.168.0.10. The DSR 1260 web config screen will open. Click on the Setup tab (top row). Then click on Wireless Setting on the left hand column menu. Select settings based on your router's setting, Typically: Wireless Setting: On; Network Name: choose from drop down, if not there, type your router name in; Wireless Mode: Infrastructure; SuperG Mode: same as your router; Security: same as your router. Then Save.
Remove the cable connection of your 1260 and your router. Then go to Status in the web config. Click on Wireless. It should now show your router details. That's it.
Jan 24, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Epson photo 1400
seth, did u figure this out since last month? I am looking for the same, a print server that works with the epson 1400. is it too new on the market for any print server to know whether it works?
Oct 26, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260, HP All in one 2210, and IE7
Make sure your printer is on the compatibility list provided by D-Link. The list is in the following link: http://support.dlink.com/faq/view.asp?prod_id=2316&question=DPR-1260
Aug 20, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
3,879 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
