Question about Acer Aspire 1360 Notebook
Need to remove a 2.5" hard drive from a laptop
Acer Aspire 1360 laptop is the model
  • Acer Master
  • 13,433 Answers
In the bottom of the laptop you should find a cover with few screws, you may find 2 or 3 of them, the hdd is under one of them.
OR some models may have it behind the Battery, so if you take the battery off the laptop you may see the HDD there, in that case you should be able to pull it out.
the other models have it in place with screws.
Posted on Jun 27, 2009
2 Suggested Answers
  • 130 Answers
SOURCE: hi i removed my hard drive out of my acer aspire
check your hard drive to socket connection, sounds to me like eather you have the hard drive in upside down or the connection isn't secure.
Posted on Jan 11, 2010
My acer aspire 1360 wont turn on when i power up al;l i get is a black screen, the motherboard light flashes once and then goes off leaving only the power light on please help!!
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 22, 2010 | Acer Aspire 1360 Notebook
Hi Folks. After formating my Acer Aspire 1360, my Cd/DVD Drive don't apear anymore on my computer. Solutions ??
Yes.. Hello. You are having a Media Software Issue that can be solved by going to your computer Manufacturer's Support Website and Downloading/Installing any/all Updates for your Model. Here is the link to get you where you need to go, ok? :)
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Jul 13, 2010 | Acer Aspire 1360 Notebook
Bios laptop Acer Aspire 1360 is empty / broken after wrong flash
how come ur BIOS is empty....
did u FLASH ur BIOS with any firmware update....
Dec 20, 2009 | Acer Aspire 1360 Notebook
Hi i removed my hard drive out of my acer aspire 1360 laptop now nothin its blank its starts up but its like brain ded
yes you have to restart yor system again and make sure it boot from the hard drive. what the system need to run on is in the hard drive
Oct 27, 2009 | Acer Aspire 1360 Notebook
How to remove hard drive from acer 1360 aspire
Detach the machine from the power supply.
Turn the Acer Aspire 1360 over. Remove the battery.
The hard disk caddy can be seen centrally located from the battery bay (it is shiny metal). There is a piece of clear plastic attached to the back end of the caddy.
This is usually pushed back on itself under the plastic casing.
There are two screws located in the casing around where the HDD is located.
One is deepset and one is much nearer the surface.
Remove the deepset screw and put aside for later.
Get hold of the clear plastic strip attached to the HDD caddy (you may need a small screw driver to 'fish' it out). Gently pull the HDD caddy into the battery bay. It should come out quite easily, but you do need to apply consistent and mild force.
Once you have the caddy out, you will notice that there are two screws holding the HDD in it. Remove them carefully.
Remove the HDD from the caddy.
Putting back together is the reverse of the above.
Jul 22, 2009 | Computers & Internet
Aspire web connections
To go wireless:
1.- check if your wireless device is working
2.- If not you have to turn it on
3.- Select your wireless network (control panel>>network connections>>wireless networks)
4.- Connect to the network (is the network is pass protected you will prompt for a password)
If above doesn't help, please describe better your issue
Sep 25, 2008 | Acer Aspire 1360 Notebook
Laptop drive
dear sie
computer acer aspire 1360 pc dvd drive dease not book
dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ
PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE
YUORs garyfifiled@talktalk .net
Jul 28, 2008 | Acer Aspire 1360 Notebook
Acer aspire 1360
If the original hard drive was replaced in the laptop the cd that came with it will not work.
Mar 30, 2008 | Acer Aspire 1360 Notebook
Acer 1360 ..LCD is blank, I cannot see anything along no indicator for hard disk
hmmm check out your power connection. see is the adaptor giving power to your lap when you connect this to laptop. There might be an indicator at the jack point of laptop to your adaptor.
If the adoptor is not working well then try to use another one of same configuration.
Thanks
Iqbal
Mar 11, 2008 | Acer Aspire 1360 Notebook
ACER 1360
Unless I am mistaken, the D drive or partition is the partition that contains the restore feature for yor laptop. This may or may not be hidden system files. As far as the available free space on your C drive, you WILL need to either delete files and/or backup and delete files. Image files, music files, cookies temp files take up a lot of disk space. Try this and I think you will find more free space. BPCS
Dec 23, 2007 | Acer Aspire 1360 Notebook
Acer Aspire 1360 Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
