Question about Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 washer takes hours to do a single load
When you first start the machine on normal cycle it will say 1:00 hrs.
It starts fine, but then it will take hours to complete the load. Seems like it gets hung up in final spin where it does not sense it is complete. Just sits and spins back and forth, back and forth....
We had similliar problem. We were overloading the wash barrel and using too much soap. The soap was foaming causeing the washer to add rinse cycles hinse more time to the cycle. Make sure your soap has the HE ( high efficiency ) label on it. Hope this helps.
Posted on Jun 28, 2009
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Sep 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
1 1/2 PER LOAD
This is joyce
It is according to what cycle you have it set on and what kind of detergent you are using. if you use something other than HE detergent you may have a very long cycle, its trying to get all the suds out of your clothes, and yes the cycles do range that high.
Feb 11, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
433 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
