Question about PfaFF Creative 7570
Automatic bobbin winder does not stop when bobbin is full
I have a Pfaff 7570. When I put a new bobbin in place on top to wind it with thread, the automatic shutoff does not work. Any suggestions would be appreciated.
    Problem Solver:
  • 10 Answers
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Posted on Jun 30, 2009
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
How to I wind a bobbin. The bobbin fits too tightly when I move it over to wind.
Make sure you are using the correct bobbin for your machine. Some bobbins are very similar to others but are not interchangeable.
Nov 01, 2015 | PfaFF Creative 7570
How to remove and fill bobbin
Locate the bobbin access panel to the right of the presser foot. Place thumb tip in the oval hole and pull to the left, (It might also tip up, but I doubt it.) Reach in and lift and grasp the little lever on the bobbin case, pull it out. Remove bobbin from case. Select the thread you want to fill the bobbin with. Place it on the thread spindle. Pull thread trough the small round tension disc on top of the machine and back toward the short spindle on the right top of the machine. If your bobbins have holes.. thread a hole and place the botton on that short spindle. Slide the bobbin and spindle toward the metal "fence". Loosen the hand wheel by turning the center knob counter clock wise. Grasp the little thread on the bobbin and start winding a few revolutions with you holding the thread. Stop and clip that short thread close to the bobbin then continue winding until full.
When the bobbin is full. Return the hand wheel knob to it's original position. Slide the bobbin winder spindle away from the "fence" and remove the bobbin. Place the bobbin in the case with the bobbin facing you... the thread when pulled should rotate the bobbin itself clockwise (VERY Important!) Hold the lever open and replace the bobbin.
For your convenience I have located this PDF for your machine. (be patient, it takes a while to load)
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/38ca989591640b1a852575f30058c8ff/$FILE/Pfaff%20260%20.PDF
Aug 09, 2012 | PfaFF Sewing Machines
How do I fill the bobbin?
place the bobbin the winder pull the thread from the spool around tinchoner wrap around bobbin push bobbin against stop turn leaver on wheel to release needle push down on peddle it will auto stop when bobbin is full.
Jul 01, 2012 | PfaFF Creative 7570
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Can the light bulb on the Pfaff 7570 be changed without the bulb changer tool?
Yes. First turn off the machine. You need to get out the cover (cap) with the stitches number in it. Move the bobbin winder to the position to full a bobbin. Unscrew the screw near the bobbin winder. Next unscrew the screw near the thread reel holder. Pull up the handle to carry the machine and now put up this cover. Unscrew the biggest screw at the left hand, just unscrew a little. I'ts a little more down. Then pull up the cap at the left hand (the cap that have the thread trimmer). Now change the bulb and put all the caps to the right position. I hope that you understand me, my first language is spanish.
Dec 08, 2010 | PfaFF Creative 7570
I haven't used my 7570 for a few years until a couple of days ago. When I tried to wind a new bobbin, the thread did not wind tightly, but made a big loose mess, with thread extending beyond the edges of...
If your machine has not been used for a few years, chances are the oils in the machine have drained from where they should be. It might be a good idea to get it serviced whether or not you solve the bobbin winding problem. One thing I would try is to run the machine with no thread for a bit - not flat out, but just to get the oil that is in it warmed and lubricating the moving parts. Stop if you hear strange noises that don't sound right. I have a 7550 which is basically the same as the 7570, but can't think of anything that might cause your winder to behave in this manner. It is after all a pretty simple procedure. It might be that the winder was on its way out anyway before you stopped using it a few years back, and the lay-off was the last straw. It probably would not be a really expensive repair and well worth it - these machines are fabulous!
Aug 05, 2010 | PfaFF Creative 7570
How to rescrew in the part next to the bobbin winder w/ no thread
Note!!! When you removed the bobbin winder stop,the nut under the cover fell off and it is inside the machine. It is quite possible for this nut to land on a vital circuit board part and short out the expensive circuit board. Take it to be serviced and save yourself a lot of grief.
sewman7
Mar 24, 2009 | PfaFF Creative 7570
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
222 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
