Question about Boating
My yamaha 1100 waverunner will not turn on . I have a ew battery in it, but no power. They have set out side for the past 4 years. What do I need to check?
    Champion:
  • 207 Answers
U need to push mode and hold it it will display ---- push aaaa that is the factory start code for that year if that dosent work let me know and we will have to find out what code you need if aaaa works after u push the code it should say start
Posted on Jul 10, 2009
  • thomas foster
    thomas foster Jul 10, 2009
    u need to push mode and hold it it will display ---- push aaaa that is the factory start code for that year if that dosent work let me know and we will have to find out what code you need if aaaa works after u push the code it should say start
Yamaha 1100 waverunner
they dont do a 4stroke 1100 high output ! 1800HO then 1800SHO !
Aug 08, 2014 | Boating
I have a 97 Yamaha Waverunner 1100 Triple, that worked fine and we hauled it to Kansas when we got there it wouldnt start. It made a very light clicking noise, has a new battery, and starter wont engage at...
Follow the wire back from the starter. It should bring you to the relay. Many starter relays have 3 wire going to them. Usually, 1 smaller wire, and 2 larger wires. One wire will be power from the battery. The smaller wire will have power when the key is turned to start. The third wire will carry the battery voltage to the starter during starting. good luck
Jul 26, 2017 | Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
I need a fuel hose routing diagram for a Yamaha Waveraider 1100
http://www.boats.net/parts/search/Yamaha/WaveRunner/1996/RA1100U%20WAVE%20RAIDER%201100/parts.html
Nov 15, 2009 | Yamaha 12V Air Pump
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Waverunner sat for 4 months. thought battery was
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Jul 13, 2009 | Sport & Outdoor - Others
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
Boating Logo
877 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
