Question about ASUS K8U-X Motherboard
IReplacement of the adapter
It seems that the LAN network adapter was distroyed by pulse of lightning (electromagnetic field). Is it possible simply to replace it by PCI network card ?
    President:
  • 2,351 Answers
Posted on Jun 27, 2009
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
Greetings, I am a technician. However, I ran into a confusing issue with my wi-fi. My Encore enlwi-g v2 PCI wireless adapter worked fine on my Windows 7 64-bit system until I bought a new Smilodon case...
Mike, your problem is so clear and crisp... Thank you for the excellent documentation...
Here is the solution...
The wireless PCI card should be detected by any PCI slots, doesnt matter whatever may be the chipset made off...
The Light in the adapter is "OFF", says there is no power supply to the adapter and that is the reason the Wireless card is not detected...
unplug the adapter from the board and clean the PCI slot on board with a soft brush(the Pins in the PCI slot may get in contact with each other if u use any hard materials to clean)...
On the PCI wireless card clean the metallic contact surface (the place where the pci slot comes in contact with) using an ERASER and clean the dusts left by the eraser properly...
Now connect it back and check if the light is getting LIT up on the card...
Then you can also check under device manager either in Network adapters or under other devices...
Sincerely, Manny...
Dec 09, 2010 | Encore (ENLWI-G) (ENLWIG) 802.11g/b...
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
My network adapter " broadcom 802.11n newtwork adapter" is experiencing driver or hardware related issues
I think it needs dusting. do the following:
1.Open your computers cabinet and plug out the LAN card from the PCI slot.
2 Clean the PCI slot and LAN with brush
3. Insert it again in some other PCI slot if your motherboard have .
4. Install the drivers after the windows found the hardware.
Hope it work.
Jul 14, 2009 | HP Broadcom 5751 (DZ556A) Network Adapter
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
On board lan & pci slots are not working . on board lan also not showing in device manager.
Was the board recently struck by lightning? I've had several problems where lightning struck the motherboard through the lan ports, while not destroying the board itself, but just the lan port, and usually not showing up in device manager gives it away.
You will have to replace the motherboard if this is the case
Dec 30, 2008 | Intel D101GGC Motherboard
Installation of network card
chek first the netwark card is correct than u will reinstall your system
Oct 16, 2008 | D-Link DFE-530TX+, 530TX+ 10/100 PCI...
Lan card disabled
When u plug the ethernet CAT cable in the LAN card socket , so you see any light orange or green flashing on the LAN card itself.
If yes then right click on my computer >> properties >> Hardware >> device manager>> check in network adapters whether the LAN card is enabled or not
If NO the right click on it and enable it check whether it is able to receive any ip address
If u see no light at all
Then you might have to install a new LAN card on the system
Jun 07, 2008 | 3Com Megahertz 10/100 with XJACK Connector
ASUS K8U-X Motherboard Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
