The arm belts may be in a bind. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
SOURCE: embroidery arm
Turn off the machine, remove the carriage, check that nothing is hitting against the arm and try again.
Sewman7
SOURCE: JAMMED FREE ARM ON EMBROIDERY UNIT
I called my Tech (dealer) in Oshawa Ontario and he had the solution and it was simple. Just apply a little presure to the arm while pushing the return to storage possition button and it worked. I have since thought to myself that I had shut off the machine while the arm was still in the working possition and therefore (I think) couldn't recalibrate when I turned it on in the morning so from now on I will shut the machine down with the arm in the store it possition and see if it happens again. This might not have been the problem and then it may just be the cure. Thanks for answering my e-mail so promptly but I now have an e-mail for the tech in Oshawa.
Lynne
SOURCE: the embroidery arm is not working properly
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
SOURCE: My singer ses2000 does not present a dialog box
Check is the embroidery unit is leveled with the machine. If is not put something under the machine or the unit to make them both leveled. NOt being leveled causes the machine to not recognize the embroidery arm.
Also make sure your sewing pedal is unplugged.
SOURCE: my viking #1+ embroidery unit when i turn it on the arm won't move to line up to embroidery
it would be a good idea to have the machine checked
