Question about RCA P52926 52" Rear Projection Television
Color convergence out of wack
I leave for work @ 5:00 a.m. ........... When I return 3 Hours Later The Color Convergence is out... What can i DO
  • 25 Answers
A professional tv technician can realign convergence or you can try to manually realign it yourself via little knobs under one of the tvs panels near the lamps.
Posted on Jun 27, 2009
If I turn the tv off an try to turn if on again the screen is either solid green, multiple colored lines, or is constantly blinking. If I turn the tv on and off, it will eventually go to a normal screen...
The tv having a problems known as a convergence problems,it dying,going to be dead sooner or later.The tv colors lines R,B,G mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dying going to be dead.These parts on the tv convergence board,must replaced these parts to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-48WP30 48" Rear Projection...
Color converger
Yes it fixable,Must replaced 2 convergence ICS,and some or all it resistors are dead.The shop will cost U $300-350 for parts and labors.All DLP Tvs have these Convergence problems sooner or later.Just how long u use the tv hours a day.
Apr 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
3 color lines at top of screen no picture
If you do not see convergence in menu when you go to setup then you have a open fuse FL231 Next to flyback transfomer on right side there is 3 in a roll small brown rectanigler looking caps they are fuses the one in the middle is bad replace it .
Feb 11, 2009 | RCA R52WM24 52" HDTV Projection Television
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Have a philips(model 55pp9401) 55 in screen.just had the color (guns/chips/moduals?)changed because the blue was warping the top of the screen,also had some burned transisters.seemed to work just great...
unplug the convergence yoke plugs all 3 of them and then see if the set powers up. If it does the troubles in the convergence circuits if it doesnt you likely have a problem with the LSB pc board. If you need more help let me know.
Jul 02, 2008 | Televison & Video
Blurred figures and no color convergence when hitting the flash button to clear up picture
convergence ICs have failed. Heres a link where you can get replacements with free step by step instructions so you can do the repair yourself and save alot of money. The parts are inexspensive.
http://servicemanuals.vstore.ca/
Apr 05, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Color convergence out on rc 52 inch projection tv
If it is way out, it is more that an adjustment. It takes a crosshatch generator to do the convergence.
Electrode
Mar 04, 2008 | Toshiba 55H70 55" Rear Projection...
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
Convergence problem???
I am a TV tech and have had experience with this type of problem on many sets...So Far the only trouble is the 2 output ic's stk392-110 which should be replaced with the upgrade stk392-180..All three Color Amps are within these ic's for both horizontal and vertical convergence. Sometimes a resistor or two will burn out as well because of the short in these ic's. Be sure to be extrremely careful unsoldering and soldering and use good heat sink compound and fasten securely to the heatsink metal. Manual convergence calibration may be necessary after the ic's are replaced. First try Touch Focus after the ic's have been Properly replaced. This repair should be done by competent personnel and takes about 3 hours because of dis-assembly and re-assembly time. I am writing this because i have seen on this site mis-leading info. i come to these sites myself to verify part numbers and to see if there have been additional complications such as complete shut-down.
Sep 13, 2006 | Toshiba 53H71 53 in. Rear Projection...
RCA P52926 52" Rear Projection Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
