Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Skilsaw motor runs blade won't turn
I purchased an older used Skilsaw (8 1/4") Model 825. I got the saw home and plugged it in to find the blade does not turn when the trigger is pulled. The motor appears to run fine. The blade turns freely by hand, but not at all when the trigger is pulled. When I turn the blade manually it does not appear to turn the motor windings. Also, there appears to be a couple of places when I turn the blade manually where there is a little more resistance / and I can hear a metal on metal type of sound. Any ideas? Any help would be greatly appreciated.
  • 2,176 Answers
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Posted on Jun 27, 2009
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Witch way to turn the blade bolt on a 10" table saw
I'd be surprised if it were anything but a normal, right handed thread.
So, put on some leather gloves, block the blade from turning with a piece of scrap lumber. Use the appropriate size blade wrench and, I assume you're removing the blade, pull the wrench toward you to loosen it. Always remember, lefty loosy, righty tighty and you'll never wonder which way to turn it again. Obviously if this method tightens the nut rather than loosening it, it's a left handed thread and needs to go the opposite direction. Should loosen/tighten rather easily, so don't force it one way or the other.
Aug 31, 2014 | Skil 10" 60T Skilsaw Circular Saw Blade -...
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Nov 18, 2009 | Saws
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
1,134 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
