Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
I own 1sansui cassette deck tape D-1000W and Compu Receiver Z-5000X. There is difficulty in playing cassettes on Tape no. 1 of Deck 1000W . The cassette does not play instead when pushing the play key, the cassette tape runs at much faster speed as if we are doing fast forward. Secondly, there is problem of stopping the sound intermittently from the speakers automatically whereas the cassette plays on the deck and full signals visible on deck for bass/treble showing the cassette as playing.
My Email Address: nkjkt@hotmail.com
    Problem Solver:
  • 5 Answers
I have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
Hi, I have the same deck as yours. I think the problem might lie with the dubbing facility . Check on the right hand side , two buttons: dubbing high and dubbing normal. The dubbing high is probably stuck. Fiddle around with it and press the dubbing normal to try and cancel the other one. Make sure that when you play a single cassette that you use deck A only and that deck B is empty.
Posted on May 02, 2008
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Posted on Mar 24, 2008
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
How do I hook up a rsb11w dual tape deck to a technics sa450 receiver
Hi! This is normally relatively easy. You just connect the tuner output to the line input of the deck. Normally this is done with the amplifier where the tuner go to the tuner and the tape deck to its connections just line out to the cassette input and the cassette line out to the tape input of the amplifier
Oct 04, 2014 | Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
My DA-T500 is stuck on Tape and wont change to turntable or radio
You might have a gummed up switch. Try some contact cleaner and go from there.
Apr 29, 2012 | Computers & Internet
Connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
To connect your cassette player to your receiver, you may have to use an RCA-type of plug (you know, the red & white plugs on both ends.
BOB (June 23rd '12 3:45am)
Apr 20, 2012 | Yamaha KX 390 Stereo Cassette Deck Single...
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Aug 03, 2008 | Audio Players & Recorders
635 people viewed this question
 Grubhead
Grubhead
