Question about Frigidaire Refrigerators
Why does the door not close right ( a bigger gap at top open side of door) I would like to know if there is a way to adjust the door. The model no is FRT22TGCW2. Thank You
  • Official Brand Answer
  • 2,267 Answers
Good Morning Ray,
I understand that the door on your Frigidaire refrigerator, model# FRT22TGCW2, does not close correctly. I see that there is a bigger gap at the top open side of the door. You are able to remove the door and resituate it, so it closes correctly.
Before removing doors, be sure freezer control is turned to OFF. Remove all food from doors. Unplug refrigerator. Remove toe grill.
Trace around hinges with a soft lead pencil. This will make it easier to realign doors when they are replaced. Completely remove one door before starting to remove the other.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on Jul 03, 2014
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
SOURCE: bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Posted on Dec 04, 2008
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
SolutionGuy
  • 331 Answers
SOURCE: Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
Posted on May 29, 2009
SOURCE: Refrigerator Door not closing properly
doors hang unevenly
Posted on Aug 31, 2009
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Replaced Window Regulator, Works but when going up least a gap and doesnt close right
you have to make sure the alignment is correct when fitting new regulator, they leave around 5mm adjustment on the securing bolts to adjust the window, check these and refit always check before fitting door card etc. also on so models there is and adjuster on the arm that will need setting as well as this is angle alignment.
Nov 28, 2017 | 1998 Toyota Camry
I have a Miele G 892. How do you realign the door? The top of the door needs to shift about 1/4" to the right. Thanks Sal
Close the door until it touches the receiver so door is still open by about an inch or so then adjust the feet up or down till gap even on both sides of door in relation to side panels achieved
Feb 25, 2011 | Miele G880 Dishwasher
I have a LiftMaster garage door opener.When the door closes it is not completely closed on the right side. It has about a 1/4" gap at the bottom. It starts closing evenly but when it is about 2 feet...
SOUNDS LIKE YOU MAY NEED A SERVICE TECH.
IF THE CABLES ARE NOT RUNNING PROPERLY ON THE DRUMS IT WILL CAUSE THE PROBLEM YOU DESCRIBE. OR THE DOOR COULD BE CATCHING ON SOMETHING (DOOR JAB, TRIM ETC.) AS IT CLOSES.
I DON'T RECOMEND TRYING TO ADJUST THIS YOUSELF A PRO CAN DO IT IN ABOUT 10 MIN. IF YOU START MAKING ADJUSTMENT WOITHOUT KNOWING EXACTLY WHAT YOU ARE DOING YOU WILL PROBABLY JUST MAKE IT WORSE.
THE SERVICE CALL SHOULD BE $ 50.00 - $100.00
ALSO DON'T CALL A HANDYMAN ETC. ONLY A QUALIFIED DOOR REPAIR TECH.
HOPE THIS HELPS
Oct 26, 2010 | liftmaster Chamberlain Garage Door Opener...
It sounds like a door spring problem. Here is a website with a video of adjusting a door with extension springs.
http://www.diygaragerepair.com/Extension-Springs-s/296.htm
Oct 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
Refrigerators Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
