Question about Sony KDS-60A2020 60" HDTV
Same Problem TV kicks off and on, while the power light blinks. Has anyone been able to get any info out of Sony? When I called the tech was stumped. Help!
    Genius:
  • 1,112 Answers
Hi:
Have you tried replacing the lamp first, this is the most common failure on this model.
Posted on Feb 08, 2010
Sony BRAVIA Fails to fully Power ON. TV shuts off when backlight should kick in, after logo lights and fades. 'standby' blinks 6 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Feb 29, 2016 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Why won't my mitsubishi tl-3040 tv power on?. All that I get is the power button to blink once when I plug the power cord in. Any answers?
When a power supply starts, It is no guaranty all voltages are available. And when they are available no guaranty the power switch works perfect.
So many (even very small) things can be wrong. Only one fault in the whole chain can spoil the fun. If you are not a tech, please contact a repair centre.
To check your remote, Point the remote to a digital camera. A camera on your phone is great too. Then press buttons you don't thrust on the remote and look if you see a light flicker on the remote. Press the button several times. If you don't see a thing replace batteries and try again.
Jul 16, 2014 | Mitsubishi Televison & Video
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Power led lights blink 9 times, no power to television beyond that
Call a good TV Tech and tell him about a Sony Recall on this TV concerning the S2 Thermal IC and Fuse.This causes the 9 blinks.It is an error code. S2 Thermal sensor IC and fuse
Jul 29, 2009 | Sony KDS-50A2000 50" HDTV
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
36 inch sony wega trinitron
I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
I will buy a new tv now--definitly not a Sony.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No power black screen standby light flashes
Hi, Most new Sony TVs have a built in self-diagnostic feature. One of the led lights would be blinking. The number of blinks (on/off) is indicative of a code. The code represents a system fault. For example on some versions, 3 blinks indicate diagnostic mode where the builtin protection has kicked in (very likely a powersupply problem). How many blinks is the standby light doing? Due to the technical requirements to repair this TV, you would probably require the services of a qualified TV professional very familiar with Sony models. You can try a hard reset by unplugging the unit off from the mains for a couple of hours. If a no by then, we're back to the tech. Good luck and kind regards.
Aug 26, 2007 | Sony KV-27S42 27" TV
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KDS-60A2020 60" HDTV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
