Question about Keurig B50 Coffee Maker
I have a model 50 Keurig that started tripping the 15 amp GFI in the kitchen. I went to the opposite counter with out the GFI and had no further problems with power.This a.m. the machine was trying to heat the water but would never reach the "ready to brew " prompt. What do you think this might be?
  • 26 Answers
Most Keurig cofee makers will trip 15amp GFI'S .
So you should unplug the machine take all the water out wait about 1/2 hour . Then plug it into an outlet that has at least 115volts and 20 amp breaker or fuse . You can purchase plu in testers at radio shack or electrical supply store.
let me know.
Posted on Aug 04, 2009
Microwave clock and panel was lit in am wasn't used but in evening when went to use it isn't lit and won't work at all
Hello Anonymous
At the risk of starting with the very basics, when you say that the clock and panel aren't lit and wont' work at all, the first place to look is the wall power. You may be missing power from the wall because:
  1. The microwave isn't plugged in. Someone may have yanked a plug to plug in a mixer, phone charger, thanksgiving animated ornament, or what have you. Trace the cord back and make sure it's plugged in.
  2. Make sure the outlet has power. Take some plug-in-able item and plug to the outlet and see if it can turn on. If not:
  1. A number of kitchen outlets may have GFI switches, especially if they are anywhere near sinks. The GFI may have been tripped. There should be a reset switch in the middle of the plug. See if it's tripped, and reset if necessary.
  2. The breaker may have been tripped. Most kitchen circuits are wired to 20Amp breakers. If this is elsewhere in the house, like in an entertainment room or such, it is likely a 15 Amp outlet. Microwaves can draw a fair amount of power. Someone using another kitchen appliance, hair dryer, or what have you, on the same circuit, may have tripped the breaker. Newer code may specify an AFI or GFI breaker for kitchen outlets. In that case, a fault with something else on the circuit may have tripped the breaker. If that is the case, and it trips again, talk to an electrician. You don't want a fault like that undiagnosed.
    3) You may also want to try plugging the microwave into another outlet, even if the normal outlet seems OK
    If there's wall power and a good plug-in, then you work back to the microwave itself. A number will have fuses. Also, there may be interlocks that kick in if, for instance, the carousel rotation is impeded - that can mean something on the carousel is hitting a wall, which can risk tipping something over and spilling, or risk mucking up the reduction gears for the carousel axle if it keeps pushing.
    At that point, looking for specifics on your microwave model will be needed. You may also try the Microsoft Support approach - i.e unplug it for 5 minutes, then plug it back in and see if it works.
    Hoping this helps, Good Luck!
Nov 18, 2015 | In Microwave Ovens
When refrigerator is turned on, gfci above kitchen sink trips
refrigerator can not be plugged in to gfi due to load on compressor start up could draw up to 15 to 20 amps for a split second on start up and pop gfi
Aug 27, 2010 | Dometic RM2652 Refrigerator
Turned on, heard clicking, now keeps blowing GFI and won't work
Hello Rightorl...
Everythig made by man is repairable... and to
MERCILESSLY drive the point home... even
AMAZON carries part for your "B70"... (eBay too).
Just the slightest amount of conductivity
is enough to trip a GROUND FAULT... So
you are not necessarily looking for NAIGRA Falls.
Amazon...
1 16 of 291 results for keurig parts
I believe if you search online
You can even find a KEURIG Company PART supplier:
Keurig Parts Keurig Coffee Maker Replacement Parts
- Frankly...
I love coffee ... (excessively strong)
((life is short... and I am old))... Not withstanding
my POT- FILLER... CHEMEX... smart-home daily
automatic brewing capability...
I have reverted to the camp-fire brewing method...
BOILING water, removed from heat, IMMEDIATELY
gets a mega dose of freshly/finely ground PETE's
(never to see heat again it is COLD filtered through
a Melitta #6 and stored in the refrigerator...
Drained into a three quart carafe...
Grounds are immediately distributed to the redwoods...
When my sisty wants hot coffee... Microwave 90 seconds
(taste is ALWAYS AWESOME)...
Else the BOSS (she who must be obeyed) & I enjoy
our iced LATTE Coffees in the morning...
If it is too cold... we build a FIRE first.
Life is good (12 cups at a time).
Carnac the Magnificent
Oct 22, 2017 | Keurig Platinum B70 Coffee Maker
Our Keurig keeps kicking off the GFI outlet when turned on. Worked fine yesterday. When the outlet is reset I can hear a click insied the machine. Any help would be great. Thank You Kevin McShera
This is not an exact science. The GFI is trying to trip when it thinks you have a dangerous short. But a powerful device will require a surge when it starts up that is always pretty close to what appears to be a dangerous short. You could switch the GFI out with one rated higher, like 20 amps instead of 15 amps. It would be harder to tell if the Keurig is drawing excessively, because it would only be a transient, for a fraction of a second. You would almost need an oscilloscope to tell what it was doing accurately.
My advice would be to try a surge protector, such as:
http://www.hardwareandtools.com/invt/u720584
The idea being that a surge protector has capacitors in it, to slow down or clip rapid current flow or voltage build up. Which should reduce any eroneous tripping. Basically this one is a plug in version of what you have in the wall, but higher quality and easier to install.
Jan 22, 2010 | Keurig B50 Coffee Maker
Maytag MGR series double oven gas burner trips GFI outlet. There is no direct shorts. Would work when bypassed GFI. but not for long. Now nothing and gfi replaced. Stove fried last one. Stove running for...
the manufacturer recommends a 15 amp time delay breaker or fuse. Which means to me that a GFI outlet will not work on this unit. most of the time it just causes more problems than it is worth? I would only use those type of outlets if code required it.
Dec 18, 2009 | Maytag Kitchen Ranges
My 48" Viking Range top trips the GFI
One leg of the power is "dead shorted" to ground. Use a Multimeter and start looking/testing to determine which component is bad.
Aug 31, 2009 | Viking VGIC3074 Gas Kitchen Range
Tripping the GFI
CHECK SPOUT LEVEL MIGHT NOT BE RETURNING TO IT`S PROPER POSITION
Aug 17, 2009 | Keurig B60 Coffee Maker
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
1,102 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
