Question about Hunter 33201 Humidifier
My "Permawick My "Permawick" filters are far from "permanent". They are disintegrating and clogging the little holes in the water exit "filter" at the top of housing. Where can I get a pair of new Permawick filters for my 33201 humidifier - and how much should I expect to pay? Thank you.
  • 114 Answers
Http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=113446&typeName=humidifier
here is the website for the filters. they are about 12 dollars a piece for one. that's without shipping and handling. if you have any other questions please let me know i'll be more than happy to help you
Posted on Aug 29, 2009
The unit is leaking water, but not from the collection bucket. The unit is in the basement, has worked well for many years, but has never been serviced or cleaned.
More than likely, the drain tube or hole that delivers the water into the collection bucket is clogged. To clear the clog: First turn the unit OFF and unplug it from the wall outlet. Use an 18 -20" long plastic Zip Tie, that will fit into the drain tube or hole. DO NOT use a wire coat hanger for this. Carefully insert the Zip Tie into the hole or tube and gingerly work it in until you reach the bend of the tube. This is where it gets a little tricky, because you must get past that bend, to be effective. Once the Zip Tie has reached it's limited reach or it has bottomed out. Slowly pull it back out, while rotating it. This will remove any clogs, so be prepared for water to follow.
Hope this helps you solve that leaky situation. Please let me know.
May 06, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Cleaning instructions
nvm :)
Features: Low Maintenance:
* Regulated Release ™ System - eliminates stagnant water while preventing mineral build-up on the wick or filter, which can impede performance in ordinary evaporative humidifiers.
* Dishwasher-Safe, Easy-Clean Base and Tank - with antimicrobial agents molded into plastic parts to inhibit the growth of microorganisms.
* PermaWick ™ - permanent wick never needs to be replaced, saving up to $45 per year in replacement filter costs.
* Top Down Water Dispersion - evenly disperses water from the top over the entire wick to prevent mineral build up that can impede performance.
May 22, 2008 | Hunter CareFree Plus 33222 Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Noise
The Hunter 33202 uses a recirculating pump to keep the aluminum mesh wicks (filters) wet. There is a vinyl hose which runs from the pump outlet to the top of the main unit (you will need to lift the main unit off the base to see any of this, much less do anything to fix the noise). The top of the hose meets the diffuser, which has several small holes to drain into that V-shaped double trough (located directly above the two wicks) which has larger drain holes on either side. If any of the holes in the diffuser or the trough become clogged, the other holes will tend to release a higher volume of water, which could lead to that running faucet sound. The clogs are easy to dislodge-- they're usually mineral deposits from the water. Another likely cause is the filters becoming clogged from dust that's being sucked in from the fan. Easy fix, also-- remove the wicks every week or so and thoroughly rinse them under running water.
Feb 13, 2008 | Hunter 33202 Humidifier
Hunter 33201 Humidifier Logo
272 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
