Setting up linksys adsl2 modem
Lol i have a prplm with my router i can't get it cennect to my xbox 360? can u help plz?
Posted on Aug 27, 2008
Hi. have just installed a linksys adsl modem to my pc. am i able to connect my fax and home phone onto the same line? i tried it and it doesnt seem to work?? any ideas
Posted on Dec 18, 2007
  • 173 Answers
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Posted on Nov 13, 2007
Want w8 foe Adsl2 Gateway Wag300n-uk driver
Repost in proper section
This is automotive questions
Aug 31, 2013 | Linksys Wireless-n Adsl2 Gateway...
How do I connect iPad to linksys x2000
Connect it using WiFi or just go to your setting and the try finding your WiFi name to connect it.
Aug 28, 2012 | Linksys X2000 Wireless-N ADSL2 Modem...
Att changed our DSL modem to a Westell ADsl2+router unit, now our cisco Linksys E1000 will not allow our networked computer in the other room to connect to the internet
one router should be the client of cannot connect both as server.set one as client mode .
dhscp seting as client mode and range it in your network. and if its single router then set dhcp as server mode to increase range
for example:
from even254
Jun 12, 2011 | Computers & Internet
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Compatibility with high speed ADSL2 Broadband
Yes, Linksys WRT160N is 100% compatible with ADSL2. Linksys WRT160N is a Broadband router.
you will not be able to use the linksys WRT160N, as an ADSL2 modem router. you should be using an ADSL2 Modem separately and connect the cable from the modem to the Linksys WRT160N. Hope this clarify the doubt.
Apr 02, 2010 | Linksys WRT160N Wireless Router
Need to re-connect to linksys
connect to your linksys using ethernet cable try configuring your modem/router again. if this does not solve your problem reinstall your wireless driver in your computer.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
Can we configure in a notbook directly wrt54gl using wireless without a PC ?
You can have multiple computers connected to the router. What seems to be the problem.
Oct 02, 2008 | Linksys Wireless-G Broadband Router
Internet connection problem Zhone 6211
After a while the net stops working then when i open the router page for the settings it starts back working
Aug 08, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
LinkSYS ADSL2 -AG241Modem + Router Ethernet
First : check your cables if its plugged in securely on each each
Second: Try to change their ends
Third : Try to replace your Ethernet cable.
If your router is connected to a modem try to isolate the problem by connecting your router directly to your computer and check f light would turn on. IF YES then thers something wrong with your modem, check it out.
Hope those simple steps ive provided helped you in way, If not pls let me know and lets keep the ball rolling.
Jun 19, 2008 | Linksys ADSL Modem + Router With 4-Port...
Computers & Internet Logo
751 people viewed this question
David Payne
David Payne
