Question about Cyberhome CH-DVD 300 DVD Player
My CH-DVD 300 DVD sometimes has no sound but video OK
I have tried reseting to factory default setting via the on-line menu but no luck. The only thing that does work is to unplug the unit from the wall outlet and the plug back-in. After this "Cold Boot" the video and sound work fine,
Unfortunately, I don't have a solution for this issue, but I wanted to thank you for mentioning the idea to unplug and replug in the unit. That's the ONLY thing I did not try to do to fix it - and it worked. I know it's not a permanent solution, but at least now I can finish watching my movie. If I find out a better solution, I'll pass it along.
Posted on Jul 06, 2009
My recorder show HOLD how to clear hold
Hello
Reset the unit to its factory settings by the following methods.
Press and hold CH Up and CH Down button on the main unit for about 5 seconds.
(Current channel line-up and television program list are cleared.)
Select "Yes" in "Restore Default Settings" in the SETUP menu.
This returns all values in the SETUP menus, except for the clock, channel settings, ratings
level, and on-screen language, to the default settings.
While the disc tray is open, press [DVD] then press and hold REC button and Play/ [PLAY/* 1.3] BUTTON on the main unit at the same time for 5 or more seconds
Press and hold POWER button on the main unit for 10 seconds. (The settings remain.)
OK.
Mar 24, 2011 | Panasonic DMR-EH60 DVD Recorder/HDD...
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
No sound
Is your set plugged into a tv via scart sockets if so check the connections movement often unseats them and turns off sound and picture etc : If they are ok check that the sound is turned on in the menu and on the menu of the television set , low battries in a remote sometimes give the wrong signals and it causes many problems like this as it changes settings without you knowing crazy but true , when I was a field engineer I used to travel round an reset scores of sets Tv,s Video,s and other Infra red remote equipment with the same fault all because of low battries . If this dosen't work sorry to say a local service engineer to check out the set may be your best course of action .. Regards Vortash
May 06, 2009 | Cyberhome CH-DVD 300 DVD Player
How do I reset the Cyber Home 300 to defaults?
Check your owners manual. find the function by using the on screen menu, turn this on by pressing the menu button This function is usually in the setting functions and is usually found by using the up and down arrows to find the settings function and then using the right arrow to enter the function. After entering the function you should find the factory reset function among the listed settings.use the up and down arrows to find this setting and place the cursor on it and press enter and it should reset all the functions to the factory settings for you. Hope this helps you with your problem.
Apr 19, 2009 | Cyberhome CH-DVD 300 DVD Player
No picture or sound
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Mar 11, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD player
try to reset it to factory settings.
Jan 11, 2008 | Cyberhome CH-DVD 300 DVD Player
It does not want to load anything.
have you tried resetting it to factory defaults?
Jan 10, 2008 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Blank Screen
This is almost the same problem for me...Please provide a solution
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Aug 04, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
106 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
