Question about Dometic Rooftop RV Air Conditioner
My duo therm roof top camper air conditioner just shut off and will not come back on. Can hear a click when turning on now but nothing else. Note that heater will not come one either.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
The click that you are hearing is the relay control board in the rooftop unit. This means that you are getting 12V to the board. It sounds like you are not getting 120V to the AC unit. Check the breakers in the breaker panel to make sure they are OK. If they are fine, then turn off the AC for 5 to 10 minutes and try again. There is a thermal protection device in the unit that prevents you from turning it right back on after a shut down. Try putting the thermostat to fan only operation. If the fan does not come on in fan only mode, then you have thrown a breaker.
Hope this helps,
Jeff
Posted on Jul 04, 2009
I have a duo therm model 57915 522c1 air unit on my camper. Turned it on and was working fine. Then it shut down. Doing nothing now. Any ideas?
water draining from condensate hole ??? if not its shut off on high water level (you don't want water dripping into your nice camper right ?)
bees are my nemesis on these they love to build mud nests in the drain holes and stop em up !!
Aug 25, 2016 | Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I have a Duo-Therm 600 Series Penguin Roof Top Air Conditioner on my Bigfoot Camper.It was put on in 2005. I turn it on, sounds like the pump is working than shuts off after a minute and nothing more...
It sounds like it is the start cap on the compressor and no you can't add refrigerant to it the can you have is 134a and the fittings are not the same
Aug 21, 2013 | Dometic Rooftop RV Air Conditioner
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm briskair conditioner
check your power supply, 5 minutes is about the time it takes to blow a breaker
Aug 11, 2009 | Heating & Cooling
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
789 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
