Question about Garden
How to load new string for FS 45C
How to load new string for Stihl FS 45C Weed Eater. The manual that was given customer at time of purchase was for a different model . A Picture of the spool for a 45C looks nothing like the spool on the trimmer he bought.
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
  • 718 Answers
SOURCE: need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Posted on Jun 01, 2009
pumpkinman
  • 1165 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
  • 89 Answers
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Posted on Nov 05, 2009
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
How to line the feed on Stihl FR 106 Weed Eater Max 420 head
could you add a picture of the particular head you're using.
Aug 22, 2014 | Stihl FS 85 Weed Eater
My stihl weed eater fs85 hard to start when hot
Try loosening the gas cap to relieve any pressure, then tightening it back up. Usually you will just need to barely unscrew it and then screw it back even before you pull the rope.
Jul 13, 2014 | Stihl FS 85 Weed Eater
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Mar 04, 2013 | Stihl FS 85 Weed Eater
My Stihl FS 85 Weed Eater gets no fire to the spark plug
older models have a pick up and condenser for spark. newer models have pick up and ignition module. the pick up rust the condensers and modules go bad. first take apart to expose flywheel then ck for rust on flywheel at pick up if rusty clean set pick up clearance to that of a matchbook or ten thousands of a inch.if still no spark change condenser or module.
Jul 14, 2012 | Stihl FS 85 Weed Eater
I need to see how to replace the throddle cable assembly on a stihl fs 75
Here is a link to the parts manual, there ate a few different types of throttle setup.
Oct 05, 2011 | Stihl FS 85 Weed Eater
Where can i get a manual for a stihl f5-45c weed eater
Check ebay, if there isn't one there you may want to visit the shihl website.
Aug 06, 2010 | Garden
Garden Logo
750 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
