Question about Poulan "Poulan" Push Mower
Where is the air filter located on the poulman pro 6.75 ready sta
Air filter location on the poulman pro 6.75
  • 365 Answers
It is either on the handle up near the top which they call a snorkle filter or on the side of the carbi in a square plastic cover
Posted on Jul 01, 2009
Sand getting in pool
check laterals inside filter if broken replace or put fine mess over them until you can replace old sand will go through the holes because it breaks down in size
Jun 21, 2014 | Sta Rite 21 Sand Filter System with 3/4 Hp...
How do i set up the hoses on the BHR170 pump?
front of pump goes to skimmers and main drain if inground pool skimmer if above ground top goes to inlet of filter then outlet of filter goes to pool returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
HOw many chlorine pucks in my filter?
You DON'T put pucks, tablets, or sticks EVER into a pump!!!!!
Use a Feeder for this purpose!
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
Does my lawn mower poulan pro model#PR625Y22RKP have a air filter? where is it?
Just about all internal combustion engines have some type of air filter. Clean air to any engine is extremely important. Most engines always have the air filter located ahead of the carburetor or the fuel injection system. Yours is probably located on the side of the engine under a cover with a screw in it. The cover may look like part of the main engine cover, but it will be smaller. Check on both sides of your machine, just behind the front of the engine.
Jan 23, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Where do i locate the air filter for 1984 Honda VF 1000 Thanks Terry
Most all motorcycles air filters are located underneath the fuel tank.
take off seat...turn fuel selector to off...disconnect hose from fuel filter, take off hold down bolts for tank then have some rags ready for a little fuel leakage and since your going to change or inspect air filter now would be a good time to change or spray clean your fuel filter. if the air filter is not under the tank, then just follow back from your carburetor manifolds tubes.
Apr 02, 2010 | 1984 Honda VF 1000 R
Poulan "Poulan" Push Mower Logo
235 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
