Question about Canon DR-2580C Path-Through Scanner
Canon Scanner DR-2580-C (Black lines around border of document)
Just purchased online. Canon Tech and support sent me 2nd unit, just in case 1st unit was bad. Same problem. Their software on this unit is Capture Perfect 3.0. Went through with various settings four times with two techs from Canon, still no resolution. Problem is the document scans and I see it in the Capture Perfect preview (only scanning 8/12 x 11) black and white business doucments. Nothing else. When I see the preview I can faintly tell that there appears to be a broken black frame about 1/4" of an inch around about three quarters of the doucument. When I print it directly to any of my office printers (HP laser jet 2300 or 4250), the document comes out just beautiful, i.e, no black frame lines anywhere around or near the border of the pages. But once the document is saved in a folder call, Shared Scanned Documents" and I then retriew this doucment and print, the black framed lines appear and they also appear when I send this document via email attachment. Capture Perfect 3.0 software also has the abiltiy for me to check "Deskew" for crooked document feeds; and to eliminate border and punch holes. Canon and I tried activating these features to see if it took care of the problem and it did not. I called Adobe and they sent me back to Cannon. I also tried to print the document from Adobe Acrobate vs. 8.1 and it came out even worse. We also went to a second computer and tried both the first and second canon unit. We tried new cables, negative. The lines even appear with a perfectly piece of white paper. Adobe also had me try to save the doc as a tif file rather than a pdf, but that did not correct the problem. I paid $650.00 for this dedicated scanner and it appeared to be a good mechanical unit, but perhaps it is the software or how I am handling the document once it leaves the Capture Perfect 3.0 arena and is stored?
  • 327 Answers
Re: Canon Scanner DR-2580-C (Black lines around border of...
It seems that your scanner is conflicting with previously installed software. It is impossible to say whether it is Canon or Adobe. Reinstalling Acrobat or updating it may work as trying a different folder like Desktop instead of My Documents. One or more drivers are at fault. What system are you running? 2000, XP, Linux? Update your video rendering software too. Let me know so that I can help solve this issue. Just try as mentioned first.
Posted on Nov 06, 2007
0 characters
3 Points
Capture perfect black border
Check "Border Removal" button in driver
Mar 13, 2014 | Canon DR-9080C Path-Through Scanner
When I'm scanning a document on Canon 7580 each page will show up on my computer screen with a slighly different margin (keeps shifting left to right). The document is being fed into the scanner...
Under CapturePerfect3, you can choose to deskew the scanned image while scanning itself. Also select 'Image only" radio button instead of 'Guide Plate'. The software will remove black borders around the image.
S. Mohan, Chennai, India
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-3080 CII scans only half or right side of document
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Oct 02, 2009 | Canon Scanners
Scanned Image is all black
Try uninstalling and reinstall the scanner again. Try on a different computer. If even after this the problem remains, may be the there is some hardware fault (failure of light) in the scanner. How is it in color?
S. Mohan
Apr 09, 2009 | Canon DR-1210C Scanner
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
Need service manual for Canon DR 3080C Scanner
Feb 09, 2009 | Canon DR 3080C Path-Through Scanner
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Word 2003 'save as' problem
It is possible that some .dll files in the OS are corrupted. Try running scandisk.
S. Mohan
Oct 22, 2007 | Canon DR-2580C Path-Through Scanner
Canon DR-2580C Path-Through Scanner Logo
544 people viewed this question
Top Canon Scanners Experts
 Mike M
Mike M
D. E. Hev
Mohan Sriraman
Mohan Sriraman
Are you a Canon Scanner Expert? Answer questions, earn points and help others
