Question about JVC Everio GZ-MG130 Camcorder
Jvcgzmg130u bought it in usa is it compatible with british dvd recordrers
  • 44 Answers
Re: jvcgzmg130u
Yes....BUT....You'll need your computer to convert first. Although this is the US version camorder that you purchased, the software that comes with the camcorder allows you to convert you recording from NTSC to PAL when your ready to produce your movie. You can do this by opening up Power Produce or Power Director(software that comes with you camcorder) on you computer transfering you movie(s), editing if you would like though you dont have to, then select produce movie. The options offer you what choices on what to create; file, dvd,youtube video, and so on. You'll also see an option to produce in NTSC (default) or PAL. This is the only way that your recordings can become compadable with and be shown IN color on you PAL devices. If this isnt done and you go srait to your PAL recorder with this camcorder, our movies will be shown in black and white and or a bit distorted with no sound.
c9ee7e3.jpgDONT FORGET TO RATE!!!
Posted on Jan 02, 2009
0 characters
3 Points
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Dvd player will not play dvd comes up with message "playback prohibited by area limitations"
I don't know where you are, so I will have to speak generally. DVDs made for the USA market will not play in Europe, because they have different area codings. This is about copyright owners controlling copyright. Many DVD players in Europe are actually hacked to get around this.
It isn't just Europe and the USA either, there are several areas that cannot share DVDs across borders.
It would seem that you have got a camera that is set to a different area than your DVD player. That is what is causing this error message. Sometimes you can change one or the other from a menu (you can do this a limited number of times with a DVD disk drive installed in a computer). If it is a stand alone DVD player, I would try to get it hacked to be "region free". Sometimes you can find information about this by searching the web. I can't advise further because you have not given make and model of either your camera or your DVD player, or your location, or where you bought the equipment.
Nov 17, 2010 | Video Cameras
I just bought it to a friend of mine, it has no manual and i dont know how to download the pic or videos to my computer! Do I need to install something? I just pluged in the usb cable and it appears in the...
You can download the manual (and more) from the manufacturer's web site at
Nov 08, 2010 | Canon DC20 DVD Camcorder
Need to download software for pc
why instead you try connect to dvd RECORDR and make a dvd on it then finalize it on it and play it where ever you want. I did it. It works perfectly for me and more convienient with space on dvd and there is no need for software. Good luck
Oct 04, 2009 | JVC GR-DF570 DV Digital Camcorder
Have been told by Hitachi that the camera is to old for Vista
go to electric shop like maplins that sell usb converter that IS compatable with vista and use that as a throughput for your dvd camera,,,ie.. camera out connected to usb dvd converter connected to pc's usb slot. i just bought a video card (not graphix card )from ebay for £10 that takes any video imput to record to pc.
Jun 05, 2009 | Hitachi DZ-MV580A DVD Camcorder
Bought the cam used need to know how to load the dvd looks like it might be ,missing a cartridge or something
The DVD-RAM media for this camcorder is encased in a plastic cartridge. Several companies make the media for this corder, Maxell calls it DVD-RAM Camcorder (DVD RAM 4.7) 2.8GB. You must verify it shows compatibility with Hitachi Camcorders, as the Sony media does not use the cartridge but is the same ram disc, so you could easily buy the wrong type.
Sep 30, 2008 | Hitachi DZ-MV550 DVD Camcorder
Mac compatibility
i dont think that your camcorder is compatible with mac. you can see the compatibility of your camcorder here.
try to use it in a windows OS. hope that helps!
Aug 23, 2008 | Sony Handycam DCR-SR82 Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Changing a -vr format
You're right - only DVDs initialised in VR mode can be edited on the camcorder. Those initialised in VIDEO mode cannot be edited on the camcorder, but can be played on most DVD players and can be edited on a PC.
The good news is, if you are using a DVD-RW disc you can change the mode by reinitialising it to be in VIDEO mode, but you will lose all the previous content during initialisation. DVD-R discs cannot be initialised.
See this Fixya solution for details on how to initialise a disc.
To Junie1939 - No, it's not possible to change a DVD from 'plus' format to 'minus' format, sorry - you have to go buy 'minus' format DVDs, or change the DVD reader on your PC. Remember the Canon DC210 only takes 'minus' format DVDs.
Good Luck.
Apr 27, 2008 | Canon DC210 DVD Camcorder
Which OS works with hitachi DVD camcorder?
Hitachi DVD-Camcorders support a direct USB connection (except for DZMV730A) for Windows 98SE, Windows ME, Windows 2000 and Windows XP to a IBM compatible PC.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
JVC Everio GZ-MG130 Camcorder Logo
98 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
