Question about Car Audio & Video
Why aren't my door locks working on my mitsubishi lancer
    Problem Solver:
  • 12 Answers
Cause its a foreign car
Posted on Jun 30, 2009
My 2008 Mitsubishi lancer cj my08 drivers side back door wont open from inside or outside. Small 1/4 window has been smashed and im guessing there might glass stuck in the locking mechanism but I dont know...
Wind the window down completely. You should be able to get a hooked wire down behind the glass to snag the lock mechanism. You could also call your auto club for assistance.
Sep 16, 2014 | 2008 Mitsubishi Lancer
Issues after cattery change.
Not without plugging it in and seeing what codes pop up ,as for the door locks then try disconnecting the battery leaving for a few hours then trying again ,failing which try unlocking and locking the door three times and see if this will reset it
Apr 27, 2014 | 2002 Mitsubishi Lancer
My 2002 Mitsubishi lancer won't start i changed my
Check that your plug leads are pushed all the way onto the plugs.
Check that your plug leads are connected to the correct plugs.
Check that your plugs aren't contaminated with oil after removal of the rocker cover gasket.
Did you remove the cam shaft sensor wire? Check that for it's connection.
If you removed any connectors at all, then check them all again.
Nov 11, 2012 | Cars & Trucks
I recently installed new speakers in my 2010 mitsubishi lancer and when I put the door panel back on I can no longer open the door from the inside. Also the lock only halfway closes. I can't remember...
Most mitsubushi door handels have a loop and hook type connection,
You most likley un hooked the lever.
You need to remove the door handel with the panel attached to the door and re-hook the lever.
good luck,Gary
Oct 19, 2011 | 2003 Mitsubishi Lancer
Doors lock when I turn the key in the ignition to on and unlock when I turn it back to off, just started today and unsure of why. How do I stop it from doing this? Mitsiubishi Lancer Cedia Wagon.
usaully this is done by the keyfob when u press it to lock the doors,if u take and hold down the keyfob your horn will beep1 time it will lock your doors keep holding it down it should beep again after this unlock your doors this should reset this.
Apr 05, 2011 | 2002 Mitsubishi Lancer
+Mitsubishi Lancer GLS 1996 The STOP lights will not come on
are you useing a test light to see where you have power and where you do not.check the fuse with a test light there are times you can not see a bad fuse.
Feb 26, 2010 | 2002 Mitsubishi Lancer
Key less entry stopped working
poss low charge in battery in keys..... nearer you get lower the battery life.....
Feb 23, 2010 | 2003 Mitsubishi Lancer
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
