Amana heat pump freezes up - Heating & Cooling
  • 334 Answers
Hey there, there re a couple of reasons that an ac unit freezes up. The first thing you need to do is defrost it. Then, check to make sure your filter is clean, the side of the coil the air hits first is clean and the scoop on your fan wheel are clean. Next, start it up wait about two minutes then feel the larger line that is covered in black insulation. Normally it is about 55 degrees. If it is colder, you have an airflow problem (dirty fan, coil, filter) if it is warm, you are probably low on refrigerant. If the line is warm, see what temp the small pipe is. If it is cool, you have a restriction in refrigerant flow somewhere. If it is warm to hot, again pointing to low on charge. Let me know what you find out or if you need anything else. Oh yeah, if you are low on refrigerant, make sure the leak is found and repaired or the problem will keep coming back
seth
Posted on Jun 27, 2009
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Amana heat pump cuts off for several hours at a time and comes ba
it sounds like it may be iceing up, it takes awhile to thaw then kicks back in and runs until it ices up again, remove access cover, clean condensers gently and thoroughly, don't bend the fins make sure freeze sensers on condensers are making good contact
Jan 31, 2010 | Heating & Cooling
I have a amana ptc123B35AJ split unit. Used very little had heat on the other day than turn off. the heater came back on in the off position so I unplug from wall. Today I plug it back in but will not come...
theunit is in freeze protection.what you need to do is hold the t-stat buld to bring the temp up and it will come back on shortly.dont unplug the unit.when it gets to cald it goes into freeze protection so pipes in house dont freeze
Jan 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
Setting Amana Heat Pump Thermostat.
The 2H/1C is one stage cooling two heating. Is it s touch screen or not. I mean no buttons. If not go to mode setting. Push mode till you get to heat not emerency heat abd then set temp. Keep in touch. Rus
Nov 19, 2009 | Amana PTH123B25AJ Heat Pump Air...
Service code FP
I know some manufacturer's use the code FP for Freeze Protection.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Dec 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
