Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do you take the rubber seal off just inside between door and drum!
How do you change the rubber seal inside door as its gone mouldy.
SOURCE:
  • 8 Answers
SOURCE: Replacing door seal
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Posted on Nov 26, 2007
SOURCE: replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
Posted on Nov 02, 2008
barkencoa
  • 3463 Answers
SOURCE: Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Posted on Nov 20, 2008
  • 135 Answers
SOURCE: how to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Posted on Jan 26, 2009
  • 100 Answers
SOURCE: Hotpoint Aquarius WF220 Front Load Washer dirty rubber drum seal
its a matter of removing the front retaining wire and the inner one which holds it onto the drum, an easy enough job to get off, sometimes a pain to get the inner off and on depending whether it s the screw or clamp type , screw=easy. to get the clamp off use a screwdriver to wiggle the bent wire out of the ratchet grooves. to put back is done with long nose pliers, preferably bent nose ones.
Posted on Feb 03, 2009
Can you remove the drum from lg fuzzy logic WF-T65T1 to get rid of mouldy smell
It is a big job. Why did you use vinegar and bicarbonate of soda? They cancel each other out. The drum is stainless steel, it can't smell. The smell is from mold on the rubber pipes and in particular the door gasket.
Put 2 cups of bleach in the machine and a couple of white towels or a load of white tea towels. Run the hottest wash for the longest time.
After you do a wash, dry the door seal and leave the door open for a couple of hours so everything dries out..
If it persists, get an engineer to replace the door gasket. Then keep it clean and dry.
Dec 18, 2017 | LG Washing Machines
Hi please can you help me, i have a hot point aqaurius washer, but the inside rubber round the door as gone black and mouldy
You can buy a product at Aldi/Lidl to clean the inside of washing machinest. It's not the machine manufacturer, it happens with all makes, especially if you have one of the better ones that lasts a long time. Can't remember the name of the product. It's a liquid you pour into the tray. But if you put some on a cloth and rub it into the rubber it will remove mould and discolouration.
Aug 24, 2011 | Hotpoint Washing Machines
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
Mouldy rubber seal
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Jan 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Removing rubber door ring from Zanussi Aquacycle 800
getting it off is not the problem (just find the clip at the bottom of the seal and let it off and you can pull the seal out....getting it or a new one back on is the real problem...that I am looking for help on!
Oct 12, 2007 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
