Question about Maytag Heating & Cooling
What is the best ac temp setting for a maytag 8000btu?
  • 334 Answers
You can set it where you want but be careful going below 70 degrees. Definitely do not go below 68 degrees, may cause some issues in the refrigerant flow and shorten the life span.
seth
Posted on Jun 27, 2009
We got a new Haier AC 8000btu window unit runs on 110plug in used 1summer an2months now new from Wal-Mart was working great now it's misting in water an drips are building up on the bottom inside help
there will be a drain hole on the outside bottom part of air conditioner to drain the condensation out of the device. It might be a hose or a small pipe suggest checking it for blockage .
Jul 20, 2016 | Haier Heating & Cooling
May tag window air conditioner 8000BTU #M6X08F2A. Water blowing out A/C vents. I have 2 and both do this. Thanks so much
Hello Ron,
The water is from condensation.
  • These units have to have a pitch. Your units are mounted too straight (90 degrees), the pitch or inclination is supposed to be around 2 to 3 degrees outward ( toward the back of the unit)
  • And also there may be a rubber plug on the bottom of the AC for drainage.It has to be taken out.
Maytag Air Conditioner Installation Instructions
Jun 22, 2015 | Heating & Cooling
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Red power light flashes on an LG 8000BTU AC
Called LG. It's an alarm that's preset on your unit to chime at regular intervals (300-500 running hours) to remind you to clean your filter. Turn the unit off, unplug it, wait a few minutes, and turn it back on. All done.
Aug 07, 2012 | LG Heating & Cooling
MANUAL 8000BTU AIR CONDITIONERNEED BOOK
To provide the manual you're requesting, it will be necessary for you to furnish the correct model number of your AC unit.
Thanks for choosing FixYa.
Sep 04, 2011 | Haier Heating & Cooling
My oven will not heat up, at best it may get warm. Please help
one of three possibilities: a hotspot in element(check for pitted discolored area in element)where current cant get thru/defective thermocouple(controls oven temp cycling) bad oven temp control(control you set for temperature
Jun 29, 2009 | Maytag Ovens
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
