Question about Dishwashers
Can't unlock dishwasher door? - Dishwashers
    President:
  • 3,085 Answers
Hold the reset button in while turning the power off then back on.
Posted on Jun 28, 2009
How do I unlock my dishwasher door?
To avoid damaging the mechanism, you must remove the cover of the dishwasher and with a screwdriver blade can unlock the door from inside.
Jul 04, 2013 | Cars & Trucks
I have a Jenn Air dishwasher and the door latch mechanism has been "locked" but teh door is in the open position, how do I unlock the mechanism. I have pushed the het button three seconds but this me
This happened to me. After replacing the board for $100, still happened. I messed with it myself... Reach under the counter to where the "catch" is. Mine is white plastic. Mine had a bit of movement side to side (like 3mm). Try sliding it to one side or the other and see if the door will shut. I spent $100 I did not need to spend and hand washed dishes for 6 days waiting for the part! Good luck
Jan 05, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher door won't unlock
replace the electronic door lock
Aug 12, 2012 | Maytag Dishwashers
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher door lock does not unlock on my GE quiet profile 3 dis
Sounds like you door safety interlock switches, are faulty, these can be easily replaced, at reasonable cost.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-door-switch
http://www.rd.com/how-to-repair-a-dishwasher/article18243.html
http://www.ehow.com/how_5676347_replace-door-switch-dishwasher.html
A DIY links above. it is pretty easy, you may even be able to adjust your one too.
Apr 06, 2010 | Dishwashers
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Maytag dishwasher model mdb9100aww will not turn on I checked and reset the breaker and also checked to see if any wires were loose
did you check the door lock mechanism? if it is not locking the door properly, the machine will register an unlocked door situation and will not start. 250
Nov 07, 2009 | Maytag MDB9100A Dishwasher
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
