Question about Samsung CLP-315W Laser Color Printer
Paper stops half way through the fuser, every time! I've completely removed everything not needing a screwdriver and cleaned out the paper with compressed air. Still chokes half way out.
    Problem Solver:
  • 5 Answers
There has to be something stuck for it to stop right in the middle of the print!!!!!!!!!111
Posted on Jun 27, 2009
What can I do :Error 13.02.00 paper sticks in fuser
Try a Maintenance Kit. It will have a new fuser with it and should help with the problem
Feb 24, 2015 | HP Color Laserjet 3550 Printer
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Printer stops at the exact same point every time.
The paper sensor in the fuser unit is faulty. You will need to replace the fuser unit.
Aug 05, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
May 26, 2009 | Samsung CLP-315W Laser Color Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
The copied paper is half soiled with fuser oil.
Pull out fuser unit and remove the top. ( let machine cool down, VERY HOT!!) does the fuser web need replacing ( looks like a white paper towel roll) it has fuse oil on it. is it overflowing?? try cleaning, do not spill on floor it is very slippery and hard to clean up.
Jan 22, 2009 | Canon CLC 1000 Color Copier
Paper jam in fuser
Remove the right hand side cover of the printer, (loosen the two screws, one is at the back).... see the small stepper motor at the top right?
Rotate the white gear teeth connected to it, just visible, DOWNWARDS, ANTI CLOCKWISE, using a blunt screwdriver or something, a few teeth at a time, this will eventually rotate the fuser roller and the paper will come out of the bottom of the fuser.
Oct 25, 2008 | Konica Minolta Magicolor 2450 Printer
Fuser
on the paper exit end of the copier you must remove 3 plastic covers
1. one that the paper exits and lays on 2. upper cover {have to slide upper half of copier to left to get to the screw} 3 small plastic cover pops out right behind where paper lays as it exits.
pull back black plastic sheet
undo 3 connectors
remove 2 screws with a phillips #2 offset screwdriver
fuser lifts up and out-very tight quarters here go slow and easy
need any further assistance just ask!!
May 06, 2008 | Canon ImageClass D880 Copier
Words Copied Multiple Times
Yes Cartridge problem is what causes double imaging 95 % of the time, there is a rubber blade in the drum unit that wears and doesn't clean off old image from drum. Have known this fault to be fuser at times, the way to tell is to get a print to stop half way threw machine by openning door during print, remove cartridge and look at print, you want it to be stop before the fuser(hot bit) but after the drum, image still rubs off if pre fuser and then you can see if defect is present before paper travels threw the fuser, but in your case I think you will find it is not the fuser it is toner cartridge.
Nov 24, 2007 | Office Equipment & Supplies
Samsung CLP-315W Laser Color Printer Logo
195 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
