Question about Crown CE2000 2-Channel Amplifier
I have Crown ce2000,it turns off after a short period then on then off ect.
    Genius:
  • 1,175 Answers
Hi...
IF all the outputs are connected right and it still does that..Take it to a tech..You have bad output transistors
Posted on Jul 30, 2009
HOW CAN I REPAIR CHANNEL ONE ON CROWN CE2000 IT IS NOT WORKING TWO WIRES BECAME IN CONTACT WITH EACH OTHER
The power amplifier section should be troubleshoot for shorted output IC or transistor. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 21, 2015 | Crown CE2000 2-Channel Amplifier
How much watts is the crown ce 2000
Depending on the configuration of speakers you have it will deliver different amounts of power up to 1950 watts when used to power a single 4 ohm speaker. Typical usage would be powering a pair of 8 ohm speakers, in which case it will deliver 400 watts per channel/ speaker.
Sep 16, 2011 | Crown CE2000 2-Channel Amplifier
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
Hi - trying to repair a CE 2000 crown amp. need parts R 33 (crown did have stock) R 36 crown said they dont see it in their list also LM4701T crown also said they dont know what that part is. i have...
I have a working CE2000, I might be able to help you identify the value of the parts....please send me pictures of the part location and indicate with an arrow.
yadsyon@yahoo.com
Aug 17, 2009 | Crown CE2000 2-Channel Amplifier
Fuse for crown ce2000 amp???
The problem is not a fuse. The red light indicates that the unit is in "protect" mode. This means that a problem was detected in the final amplification stage and the unit is prevented from turrning on completely to prevent damaging either the speakers or the amp further. These are not the easiest to repair without prior experience and I would not suggest you attemt the repair. Please seek an authorized Crown repair center for assistance.
Dan
May 07, 2009 | Crown CE2000 2-Channel Amplifier
I have a crown ce2000 amplifier that need repair is there parts available?
Parts should be available both on the secondary market as well as from Crown. What parts do you need?
Dan
Mar 25, 2009 | Crown CE2000 Amplifier
Crown Amp Possibly Blown??
Hi, probably worth fixing, Crown gear is generally reliable, but this one has failed for some reason. Puffs of smoke are not generally good... If it has blown an output array, expect a costly repair.
regards
Graeme
Apr 03, 2008 | Crown CE2000 2-Channel Amplifier
CE2000
clipping as indicated by its light? if so then you have overdriven your output. i dont know about Crown their protection but normally such indication you have problem with either your load speakers maybe shorted but still audible or maybe your input stage overdriven also.
redrivera
Mar 17, 2008 | Crown CE2000 2-Channel Amplifier
No sound
check your speaker wire, or may be you have a shorted speaker. disconnect all speaker before you turn on your amplifier again.
Jan 20, 2008 | Crown CE2000 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
216 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
