Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
I have a Poulan pro 4218 that has only a few hours on it. Ran fine yesterday. Today will not start. Checked the spark plug... No spark. Replaced the spark plug... still no spark.
    Brigadier General:
  • 4,088 Answers
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Posted on Jul 04, 2009
Changed the pull chord, why wont the flywheel turn?
Brand new? Is the chain brake on? IF you take the spark plug out and try does it turn?
Apr 30, 2018 | Poulan Garden
I have a poulan 4218 chain saw will start but when i pull throttle it dies, open gas cap and gas sprays out
There is a air/fule ratio valve on the side of the carbarator it's adjustable with a flathead screwdriver. Turns this all the way in clock wise then back it out 1 1/2 turns counterclockwise. Once the equipment starts you may have to make some slight adjustments. For a person that dose not know making these adjustments can be difficult. One tip I can give is once it starts you should hear a trickling sound that sound normally means it's in its correct adjustment.
Check a few thing before you do any adjusting.
Check that your exhaust is not clogged dirt dobbers tend to make nest in the small hole.
Check that the fule filter and lines are in good working condition.
Check spark plug or replace.
And replace any old gas. Gas these days has a poor quality and shelf life. Gas that goes beyond 30days should be replaced. Also try to buy non Ethanol gasoline
also check the air filter. If these things check out ok then proceeded with the adjustments. If it still won't run correctly you may need to clean the carberator. Let me know if you need any additional help.
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Jul 23, 2016 | Poulan Pro 18" Quick Adjust Chainsaw Bar &...
Car won't start.No spark.
You'll need a repair book or shop manual to check the circuits going to the coils. Could be a relay, crank or cam sensor, or wiring problem.
Jan 15, 2014 | 1996 Mercury Grand Marquis
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not start.got gas and spark.loosenthe gas cap firer but would not stay running.thank you.
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Aug 13, 2009 | Poulan Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
905 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
