Question about Logitech X-540 Computer Speakers
Speaker static when volume is changed - Logitech X-540 Computer Speakers
    President:
  • 1,185 Answers
There is dirt or corrosion on the track of the potentiometer for the sound
One test is to rapidly turn it full on and off about a dozen times (with the unit powered down ).
If there is anything on the track that sometimes shifts it or polishes the track clean
Proper fix is to get a tin of switch cleaner with a lubricant in it such from Tandy or Maplins take off the knob and spray a good dose down between the shaft and the retaining nut.
Give the knob a few good full rotations and check it out
If that does not work you need to remove the covers to get access to the potentiometer to get some cleaner inside it
Posted on Jun 27, 2009
2 Suggested Answers
damneddle
  • 1607 Answers
SOURCE: The right speaker is suddenly making "cracking" or
Hello.
Exchange the wires/plugs of the left and right speakers so we can know of it is the speaker or the wire that is faulty.
Update me.
Posted on Jul 16, 2011
Audio cable diagrams
could be a broblem with your sound card and its drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Apr 17, 2012 | ASUS P4GE-MX Motherboard
Static in speakers even at minimal volume
try to change the location of you desktop PC...because some static sound is came from the other device creating static...like lantern with ballast ..etc
May 26, 2010 | Dell 5650 Computer Speakers
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Pioneer VSX 816
The rear signal is generated and separated internally, if either the processing is not correct or the rear channel amplifier has a problem, you can get this type of behavior. Does the static happen more often at higher volumes or is it purely random? Does changing the volume make the static louder or is it always the same level?
Dan
Mar 18, 2008 | Pioneer VSX-816-K/S Receiver
Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Feb 12, 2008 | Logitech Z-540 Speaker
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Logitech X-540 Computer Speakers Logo
548 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
