Question about Garden
How do I replace the line on the spool? - Garden
  • Jody DeVogel May 11, 2010
    can you give me the make and model of the trimmer? I can instruct you accordingly.........
  • 1,041 Answers
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
How do you remove the spool on an echo srm-2100 trimmer
Most units like yours has a tap head feed spool. To get to the line spool, you need to push the spool inward and rotate it to release it. The line spool is spring loaded, hence the need to push it in and rotate it to get it to release. You return the spool to the trimmer head housing after loading new line on it the same way, in reverse. Hope this info helps.
Sep 17, 2015 | Echo Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Having trouble replacing trimmer line
Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
Please read all the way through this before beginning to actually rewind the spools.
1. Pull the spool off of the head. Clear the dust and debris out.
2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
You should be good to go.
Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
Best regards, --W/D--
Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
Hi I use all the nylon on the spool when cutting edges with in a 5 meter length ( 3 spools to do 15m approximately) Grass length 30 to 50mm
Hello. W/D here.
It sounds like the line is wound on the spools backwards, or the spool itself may be damaged. Here's what to do to fix it if it is improperly wound:
Jan 31, 2011 | Garden
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 21, 2009 | Black & Decker Garden
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
