Question about Sony KDF-E60A20 60 in. LCD HDTV
I have a sony kdfe60a20 the red light blinks 3 times
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 3 Answers
Ok, the above solution would be a good one if this unit was a LCD panel TV. Backlight Inverter Boards are only used with LCDs. This unit is a Rear-Projection, 3 blinks is gonna be a problem with the power supply, so he was right about that.
Posted on Aug 18, 2009
Kdfe60a20 6 blink
Yes the power supply board is notorious for blowing caps and tv repair kits .com has a good DIY kit for this problem.
Oct 08, 2012 | Sony KDFE60A20 60" LCD HDTV
Sony kdfe60a20 wont stay on
When it goes on does it come on with a very dim screen and then shut off?
When its off what lights on front (led) are blinking?
Mar 15, 2012 | Sony KDFE60A20 60" LCD HDTV
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a sony kdfe60a20 that has a blinking red light. It blinks 4 times, pause, 4 times, over and over. Whats wrong. can someone please help me!
The tv power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 22, 2010 | Sony Televison & Video
Light blink 3 times
If this is a Sony dlp then check the lamp door for warp, if this is not a Sony need model and brand. Or if it is a Sony but not a DLP then still need model.
Sep 13, 2009 | Sony KDF-50E2000 50" HDTV
Blinking red light 3 times on sony 34hs420
Ur high voltage transformer it dead.The big block of plastic with the red wire with a cap hook to the CRT(ur tv tube).It call the FBT,
the Flyback Transformer that thing it dead.
Sep 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Oct 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
234 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
