Question about NetGear WGPS606 (WGPS606NAR) Print Server
Connecting WSGP606 and WNDR3300 together using 2.4ghz and 5ghz.
Hi I have a WNDR3300 Netgear router, and a Netgear WGPS606 print server. If i run the WNDR3300 at 2.4 and 5ghz i am not able to connect the Print server at the WNDR3300 if i use only the 2.4ghz there is no problem. Any one that has a sollution would be great because would like to use the 2.4ghz for the print serv. and the 5ghz for the pc's thankx mike
  • 1 more comment
  • mike_lenior Jun 27, 2009
    Problem is when the Wireless-n router is configured with both 2.4GHz & 5 GHz the printer server would not connect to the router. the pc's are working fine. If router is configured as 2.4ghz only printer server works fine.
    Maybe i was not clear, running the 2.4ghz and 5ghz at the same time on the router, the pc is working at the 5ghz without problems, but i am not able to connect the printerserver on the 2.4ghz band. If i rung only 2.4ghz on the router bboth either the pc and printer server is working..
    Hi, Thankx, but seems that i found the sollution my self. If you set the printerserver in to 802.11g only instead of 802.11b and 802.11g its working perfectly !! so this problem is solved and could be closed
  • 13,433 Answers
I assume you mean that you do not wish to be charged - since you solved it yourself?
billing support - premium.support@fixya.com they will respond on monday.
Posted on Jun 27, 2009
  • 2,071 Answers
Just click below for more set up information:
http://www.wi-fiplanet.com/reviews/print.php/3762551
Hope it may helps:
Regards:
VOTIT
    Genius:
  • 1,269 Answers
You know it is not possible for the 2 wireless bands to operate at the same time. It is only possible if your wireless computer has 5GHz-capability adapter, but I think your PC is only limited to 2.4 GHz. What you can try is to change the channel on 2.4 GHz different from 5 GHz channel. Example, set the 2.4 GHz to use channel 11, and the 5 GHz to use channel 1. They won't conflict with that. Remember, your PC must have 5 GHz capability, it's called a Wireless-A cards, which happen to be rare nowadays.Wireless-A adapters use 5 GHz frequency only.
  • 355 Answers
First - let's get an understanding of what we're dealing with.
Wireless-n can operate on both 2.4GHz & 5 GHz - Wireless-g is 2.4 GHz only.
Next - due to the increased attenuation that occurs at higher frequencies, a 5GHz transmission at any given distance will always be weaker than an otherwise identical 2.4 GHz transmission at the same distance.
Because of this increased attenuation, your 5GHz wireless-n signal will be weaker and cover less area than your 2.4GHz wireless-g signal, however, if you re-configure the WNDR3300 to use the 2.4GHz radio for wireless-n you should see the increased range you are expecting.
Wgps606 sets up printer and is connected to bt homehub but when trying to set up laptop on network the print server is not recognised. Any suggestions?
Hi
You can add your laptop manauly to your network(wgps606)
please let me know operating system so that i can write ,how to fix it
Thanks for using Fixya
prakash
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Hi there, can I use the WGPS606 as an AP ? Many Thanks
I understand that you want to use the print server WGPS606 as an access point. Regarding the concern, please note that it is not possible to configure or use this device as AP. This device however can act as as wireless bridge. It can connect wirelessly to the wireless network of your wireless router/ap and provide wired connection.
Hope this helps.
Sep 24, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
WGPS606 does not like printers
Hi, visit the link below to check the compatibility list of this print server. If your printer is not listed then it means that it has not been tested with this print server and there is equal chances for its nonfunctioning with the print server.
for further support with any netgear product visit my.netgear.com
Do rate it, if it helps.
Regards
Anand
Aug 02, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Connectivity
Perhaps an ip conflict. If so, assign server an ip outside of normal client range.
May 22, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Can't connect WGPS606 wireless printer server to cable router
suggest plugging print server directly into p.c via blue ethernet cable during setup. Then run setup program and then pick an ip address that works with your router (in same network ip range of router) that does not clash . I would use print server as a switch if it is close to the router by ethernet cable between router and wireless print server. Then both should work
Wireless to server and other wired computers as well .
Feb 06, 2018 | NetGear WGPS606 (WGPS606NAR) Print Server
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Open Questions:
NetGear WGPS606 (WGPS606NAR) Print Server Logo
146 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
