Question about ASUS P4P800-X Pentium Motherboard
My system freezes
It freezes mainly in dual channel. When I put it in single channel it works better
  • auras_marga Nov 08, 2007
    I have: TwinMOS DDR kit 512MB 400MHz (256MBx2) Dual Channel kit. I have already changed the mother board twice for the same problem in about 2 years. This would be the third time. It is still in warranty period
    Genius:
  • 1,601 Answers
What memory do you have in it?
If the memory is not dual channel it will freeze
Posted on Nov 06, 2007
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
http://waterheatertimer.org/Intermatic-freeze-controls-and-parts.html#1202
http://www.amazon.com/dp/B003Y5EY6E/?tag=waterheaterti-20
http://waterheatertimer.org/images/178T24-thermostat-wiring.jpg
http://www.amazon.com/dp/B003P52CKS/?tag=waterheaterti-20
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Gene
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Can you tell me what is the difference in performance without having Dual-Channel working as it should,compared to my present situation meening NO DUAL-CHANNEL working??
Dual channel means two channels of memory. there are two configurations you can use. you can use single channel method which has twoo ram sticks running on one channel or you can have a seperate channel for each ram stick. Dual channel is said to be the better way to run it because it increases speed of the ram. Now assuming you have 4 slots for ram. to use dual channel you have to run 2 sticks of the same value (MB) right next to each other. You cannot run 2 sticks of different values in dual channel mode. In the case that you do the sticks would pair together on a single channel. Hope this helps you better understand.
Mar 28, 2011 | Biostar TPower I45 LGA 775 Intel P45 ATX...
Yes I know that order into whitch slots i should put the memory stics,1 and 3 or 2 and 4 but CPU-Z isshowing me everytime that the mobo is running in sinle mode?????
CPU-Z might mean that your computer is running in "Single" Channel. Running in dual channel mode is slightly faster. Maybe 5% or a little more. To run dual channel you need 2 sticks of identical DDR ram. Your PC might have 2 non-identical memory sticks that's why it runs in Single Channel.
Mar 28, 2011 | Computers & Internet
What is better? to put four different rams or one single ram of 4gb in p4p800 vm asus motherboard
I would suggest going with a single piece or 2 identical pieces of RAM for expandability purposes. If you want to upgrade later, you will have the option to add more RAM. From a cost standpoint, you might be better off buying 2x 2GB sticks as a single 4GB stick of RAM might well exceed the cost of 2x 2GB sticks.
Best, Hunter
Mar 03, 2011 | ASUS P4P800-VM Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
I have a dvr 625 every so often while watching tv1 or tv2 it freezes up and all i can do is go over to the box and push and hold the power button to reset the box to get it working again. dish is trying to...
Press menu-6-1-3. Now select details and scroll all the way to the end. If any value has a number greater than a single digit the box will definitely need to be replaced. I can not explain why the issue would have started after the smart card was installed other than coincidence.
I hope this assists you and thanks for using Fix Ya.
Jun 19, 2010 | DISH Network DVR-625 DTV Receiver /...
Ram wont work with computer
Dear user in my observation this is sauses due to two different bus speeds. i mean both RAMs dont have the same bus speed. thats why both RAMs dos'nt work at the same time. hopfully u will understand it
Apr 23, 2009 | Computers & Internet
Dual channel memory supported?
have you checked the bios setup may not be the problem but worth a try
My computer recognized dual channel automatically do you have them set in correct Channels as they are specific for dual channel
normally labeled 1 2 3 4 etc must put dual channel ram in 1 and 2 channel
Jul 25, 2008 | ASUS P4P800 SE (890552603657) Motherboard
DDr or Dual Channel Ddr
From the manual:
2 x 184 pin DDR DIMM Sockets support up to maximum 2 GB unbuffered PC 2700/2100/1600 non-ECC DDR SDRAM memory.
So, to answer your question, for your particular motherboard, no. However, to dispute the other poster, Dual channel is better than regular DDR. It's just your motherboard does not support it.
Jul 03, 2008 | ASUS A7V400-MX Motherboard
Gigabyte mb wont recognise dual ram
please check in bios for dual boot option.plz note for dual - channel configuration your ram should have same frequency and speed.
Apr 21, 2008 | Intel Motherboard
ASUS P4P800-X Pentium Motherboard Logo
170 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
