Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony trinitron not working properly after FBT replaced...
Hi, i have a KV32 FX65B sony trinitron that stopped working. Took it to a techinician i trust and he thought the problem was with the FBT and two transistors. I ordered the exact spare parts and replaced them... started the TV and it came on after 5 or so seconds. I noticed that the image was shifted to the right by about 10 cm (4 inches) and wasn't very clear (the colors were alittle off) and after about 20 seconds the TV switches off.
What might be the problem? is it worth spending more money and time on it?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It is complicated design TV and needs fair knowledge, experience to get it repair. Do you have service manual of this TV?
  • 378 Answers
The capacitors in horizontal circuit near the FBT . probably the HOT is damaged again due to the capacitors problem.
Posted on Jun 28, 2009
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
Number FBT
Hello
Number of Horizontal Output Transformer [ FBT OR LOT] for SONY FD TRINITRON KD-XBR960 is,
1-437-523-61
OK
Jan 24, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start...
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Is a trinitron kv-ts526 a digital tv?
Nope it is not, you will need a digital converter unit.
Thank you,
Jun 14, 2009 | Sony Televison & Video
SONY KV32-FQ70U BLINK ERROR
Try unplugging the TV for about 10 minutes and then tunung it on again. Try a factory
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
I'm assuming step 2 means hold down the power button.
Nov 27, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Have a 32 sony trinitron
Can you give me a model of the TV. It will be KV32?????
Nov 29, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
186 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
