Question about Amana NDE2330AY Electric Dryer
Amana dryer NED7200TW fault code b5 - Amana NDE2330AY Electric Dryer
Macmarkus
  • 2605 Answers
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Jul 30, 2011
  • 2699 Answers
SOURCE: my amana ned7200tw electric dryer turns on but
all there is is a belt that turns the drum,the belt goes on the motor pulley around the pulley and around the drum, check the motor pulley to see if it unattached from motor shaft or check the belt to see if it flipped over somehow,there is a smooth side and a ribbed side on the belt and you said the pulley is fine
Posted on Nov 07, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Posted on Nov 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: My Amana NED7200TW dryer still shuts down with no
Hi and welcome to FixYa. The symptom you describe can be caused by several things.
If the belt is getting loose the belt switch can cause it to shut down completely with no power (Item 5) This link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1364250#d1364250
Also if your dryer has a thermistor vs a thermal fuse
(Item 27) of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1363930#d1363930
it can also shut the dryer down when it gets too hot.
You should check all of your vent ducting from inside the dryer all the way through to the exit point on the outside wall (vent flapper) for obstructions / lint.
Also if you use dryer sheets (Fabric softener) you should clean your lint filter with white vinegar then soap and water / rinse. The particulate fromthe dryer sheets cakes onto the filter. It looks clean but willnot pass enough air.
This should give you something to go on to try and resolve the shutting down issue.
Thanks for using FixYa.
Kelly
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: amana dryer NED7200TW quit heating, it appears
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Amana dryer ned7200tw Thermo Fuse
Remove back to get to thermo fuse. Remove contacts. Remove screw and remove fuse. Install in reverse order.
Jan 23, 2018 | Amana Dryers
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
It keeps showing an error code C0. what does this mean.
Hi, I cannot find this error code for your dryer.
Does the dryer have other faults?
The Technical manual for the drier shows error codes, but does not include CO. The manual will help with resolving problems you may have as it has detailed instructions for troubleshooting and the solutions. See the diagnostic tests. You can also clear diagnostic codes, which may resolve this problem if there are no other problems with the drier.
You can download the manual from
http://www.manualslib.com/download/763426/Amana-Ned7200tw.html
Hope this helps you :)
Mar 04, 2015 | Amana NED7200TW Electric Dryer
My amana dryer model ned7200tw runs good but no heat
check element, termo fuse (top side of element casing) and electric box as it can run with one side (117 Volts) good and one bad..
Jan 05, 2015 | Amana NED7200TW Electric Dryer
How to install the drive belt on an Amana NED7200TW dryer?
Take a look at this routing diagram.
Here is a video to walk you thru the process.
Oct 23, 2012 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
My Amana NED7200TW runs but will not heat up. I don't get any error codes. Help.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
May 10, 2011 | Amana NED7200TW Electric Dryer
My dryer is an Amana #NED7200TW and I got a code HE on the display panel and there is no heat coming out. We tested the heating element protectors and they were fine. What could this mean? It is not in the...
HE shows up because there is no heat . Check the fuses in the panel and the heater itself. Also could be the sensor is not working to tell the control to turn the heater on.
Oct 29, 2010 | Amana NED7200TW Electric Dryer
Can't find new heater for NED7200TW Amana dryer.
Here is the part...
http://www.partselect.com/MultiModels.aspx?ModelNum=ned7200tw&searchTerm=&RefineSearch=0&Page=2
Hereis a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 22, 2010 | Amana NED7200TW Electric Dryer
Amana NDE2330AY Electric Dryer Logo
421 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
