Year old desktop usb ports went dead. Are powered
Acer desktop model ? Freinds systems
Year old desktop usb ports went dead. Are powered but do not work
  • Anonymous Mar 16, 2014
    my acer aspire 1202 desktop will not turnon, no elec power at all to tower, completely dead
    President:
  • 3,278 Answers
If multiple USB ports don't work at the same time, the problem could be the USB device you are using or the USB controller. If the controler, go into Device Manager and see if any problems (? marks). If no problems, right-click on the USB Controller and update the driver. If ? mark, contact FixYa again for further help. Good luck.
Posted on Jun 27, 2009
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? Thanks.
    Sniper:
  • 54 Answers
Make sure all five wires per port are hooked up as the manufacturer says to hook up
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
Pc wont recognize my hp simplesave 2TB external hard drive
No PC stated
No OS stated. (operating system) nor if PC is internet connected.
no Simplesafe model stated, is it the 3.5" HDD? version
id yes it needs power pack to use it. HDD uses huge currents to start up. and spin.
USB ports?
if the drive fails on all PCs, the drive is bad. (or was erased by grimlin's in the night)
plug in the power pack 12vdc is correct.
do not mix it up with other packs or boom.
then listen to the hdd case with you ear, here it spin up?
if not the pack is dead, or the hdd is dead.
here is the power pack for it sold in stores
see that model number there you forgot, to mention, MD2....~~~~
12V Mains AC-DC Adapter for HP Simplesave 2TB MD2000HB External Hard Drive HS....
the drives can fail and be good.
for many reasons.
  1. bad usb port
  2. usb port driver missing.
  3. OS virus corruptiong
  4. drive fails to spin means no 12vdc power. (bad power pack)
  5. using a laptop and expecting the weak USB ports to start HDD motor, will never happen, on large 3.5" HDD. some cant even start a 2.5"
http://www.pcdied.com/external-hdd.html
Aug 24, 2017 | HP SimpleSave 2 TB USB 2.0 Desktop...
Hp compaq dc7100c. Win-XP. All usb ports (8) went dead. All apps and Internet work fine. Any ideas? Thanks, bills
Sounds like the motherboard burnt out partially.How is your internet connected to the computer, through a usb port or other port?
Aug 03, 2010 | HP Compaq dc7100 PC Desktop
The light is off and it is not reconized, is it the power, can I fix it?
try it in another usb port. this to make sure it is the drive and not the port. if it doesn't light up in a working port it's dead. if it is less than a year old go to the manufactures web site and see if you can get a new one. unfortunately there really are no fixes for dead flash drives. -aokcomputer
Jul 23, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I was using my one-year-old acer aspire one netbook. i just left it (plugged and all) for less than 5 mins and when i got back, the screen has already turned dead. thinking that it must've went into...
you need a new battery it happened to my mom's desktop and she took it in and they told her to get a new power sorce so you most likley need a new battery
Sep 29, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5100-3357 lost function of keyboard, touchpad and USB
hello, this has been one of the most reported problem with the 5100 model. i have 2 of them, and they have done the same thing! one i had 2 find and install a new mainboard-400 bucks! not very cost friendly. i did post a solution more than a year ago, but it is a work around that let me use the acer with the dead keyboard,touchpad,usb- you must buy a pcmcia usb card, it goes in the slot on the left side of the acer 5100. then a usb mouse and keyboard will work. (you can get this cardbus adapter cheap, as 400 bucks is 2 much. these pcmcia cardbus card come with 2 or 4 ports. this will let you use the pc, it has been a great solution for me and a lot of others, been in use over a year like this. acer is no help, unless you wish 2 spend a large amount of $. the one with the new board lasted about 8 months before the usb port stopped working for the second time, i then got a second cardbus usb card and have usb again. sorry for your problem.. good luck! do as i say and the acer will work again.( a problem model) just search for pcmcia usb cardbus you will find many 2 choose from- i picked the ones with the NEC chipset, as these are reliable! be well!
Sep 21, 2009 | Acer Aspire 5100-3357 Notebook
Acer Debug went blank screen as if dead.
clear the bios by replacing the small battery on the mainboard.
Jul 31, 2009 | Acer Aspire 4315 Notebook
Usb port not working
Call acer let them replace the systemboard of your E machine.
May 03, 2009 | E-Machines eMachines Desktop PC
Audio drivers
I have the same problem wher my software detective says It,s working.But its not,Try jacking your speaker system in to spare or freinds system to make sure your speakers and wires are good.I.m thinking to solve the problem,may there is a way to hook speakers in to a outgoing USB port.if your speakers are self powered,then I.s just the question of getting the aaudio info out of
desktop and into my audio system.
Oct 22, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
