Question about Franklin Industries Franklin Chef Ice Cube Machine FIM400
FranklinChef FIM35 Not making ice
Red light (ice full) is on, but there's no water flowing over cuber, compressor not running, and there is no ice.
I drained the water from the plug on mine and it started to work. The black plastic crew plug about 2 inches from the bottom of the unit, there is a rubber stopper you have to pull out.
Posted on Jul 21, 2009
Water keeps running
where is the water running on the ice head or is this a remote water cooled condenser? If water is running all the time at the ice head into the sump tray and overflowing into the ice bin then check the water inlet valve ether rebuild or replace valve but make sure the water low sensor is not calling for water when the sump tray is full of water.
Jan 12, 2014 | Scotsman Cooled Modular Contour Cuber...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Red bulb for refrigeration comes on. When cycling manually, water enters the area where is should be made. Nothing is cold. Fan blades turn free by hand, but do not run during the manual cycle. Help...
Has the CM3 controller been changed out? If so and it is the Universal service controller look on back to make sure the model- program selection switch on the side has been set to correct number.if so then unplug unit then plug back in push freeze tab let run and check all the refrigeration components. we know it is not a water problem or the water light would be lite up. If when you push freeze tab and nothing comes on and the water sump tray is full of water then replace Service controller.
Oct 11, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman cme456as-1a
Pull and clean water level switch. Check to see if water solenoid is getting power to it if so check to make sure you are getting water through it. FIRST check water filter make sure its not stopped up. if that is clear check make sure water line is not kinked. If your unit is not getting water then the unit will run high pressure and lock out on refrigeration.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Motor is hot?
Which motor is hot...compressor or fan?
Also need to know the model number.
Is this a 3-phase or single-phase unit?
Let's assume it is the compressor...Is it so hot that you can't touch it for more than a second or two? Is the compressor shutting down on internal thermal overload?
Compressor body hot can be caused by a number of things:
1. Low charge (the freon acts as a coolant for the compressor).
2. Electrical imbalance (3-phase only). (check line-to-line voltages)
3. Bearings in compressor failing (check amp draw).
4. Condenser dirty or airflow blocked in some way.
5. Condenser fan(s) not running or running backwards.
6. If water cooled condenser then water flow problem.
Hope this helps you get started.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
I have a Scotsman CME 1056R. Diagnostic water light is on
cut power to unit pick up water pump unil u see bottom of pump..try to spin manuely..chances are your pump is locked ..if spins freely ohm out motor windings..make sure ur getting power to pump
Sep 06, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Model AM-150BAF ice machine. Water was down at store last night. Now today it isnt making ice. and yes we have water today.
it often takes a full 24 hours for an ice machine to get back up and running and make its first batch of ice.
Aug 14, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Apr 14, 2009 | Scotsman Cooled Modular Contour Cuber...
Ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Franklin Industries Franklin Chef Ice Cube Machine FIM400 Logo
522 people viewed this question
Top Franklin Industries Kitchen Appliances - Others Experts
jasbo
jasbo
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
