Question about Canon imageCLASS D880 All-In-One Laser Printer
"Replace Cartridge" message despite testing 2 new cartridges
Despite testing out 2 different, fresh out of the box ink cartridges a "REPLACE CARTRIDGE" message still appears and no pages can be printed.
Re: "Replace Cartridge" message despite testing 2 new...
Posted on Apr 29, 2008
    Problem Solver:
  • 10 Answers
Re: "Replace Cartridge" message despite testing 2 new cartridges - Canon imageCLASS D880 All-In-One Laser Printer Printers &...
Posted on Nov 06, 2007
0 characters
3 Points
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
My Brother MFC-685CW Printer Wireless doesn't recognise a new colour cartridge despite having cleaned the printer head. It also is not recognised by the PC despite reloading it. Help!! Troubleshooter...
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridge(s), it is possible another ink cartridge is empty and needs to be replaced or one or more of the cartridges are not installed properly. Complete the following steps:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    1a. If the display continues to show NO CARTRIDGE, verify the cartridges are installed properly by uninstalling and reinstalling all four ink cartridges. Follow Steps 2a through 2f.
    1b. If "INK EMPTY XXXXX" (Xs = color, i.e. INK EMPTY CYAN) is displayed on the LCD, the specified ink cartridge is empty and needs to be replaced. Follow Steps 2a through 2f.
  2. To resolve an INK EMPTY message or to confirm the ink cartridges are installed properly, complete the following steps:
    2a. Open the ink cartridge cover. Pull the lock release lever(s) down and take out the ink cartridge(s). While you have the ink cartridge(s) out of the machine, verify the cartridge(s) are genuine Brother supplies with the Brother logo embossed into the side of cartridge.
    2b. Reinstall the ink cartridge(s). Lift and push the lock release lever(s) until it clicks into place and close the ink cartridge cover.
    2c. The LCD may then display:
    Did you change xxxxxx? Yes No.
    for the color(s) that was replaced. If this message appears, BE SURE to follow the instructions on the LCD to correctly select Yes or No. Select Yes if you installed a new cartridge(s) to automatically reset the ink dot counter for that color. Select No if you did not install a NEW ink cartridge(s).
    2d. After all the correct selections are made, the machine will then enter a cleaning cycle.
    2e.If the display again shows INK EMPTY XXXX, go back to Step 2 and follow the instructions to install a NEW ink cartridge.
    2f.If the machine did not enter a cleaning cycle and the display continues to show NO CARTRIDGE after reinstalling new genuine Brother ink cartridges, your machine may require service.
If your computer is not recognizing the printer you should uninstall and reload the drivers. You might consider downloading a new driver for your operating system from this site:
I recommend bookmarking thihs site for future reference.
I hope this is helpful. :)
Dec 08, 2010 | Brother Printers & Copiers
While color cartridge prints well, the black and white -- despite new cartridges -- is faint and/or blurry.
Hi, you are facing this issue as your Black ink Cartridge is empty, if you open the hud of the printer you will see there are two Cartridge, one is for Color and one is for Black, your color cartridge is fine as it will printing properly. In order to resolve the you need to change the color cartridge. If you want to replace the Cartridge by your own below weblink will help you:
Feb 22, 2010 | Dell Inkjet 720 Printer
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Nov 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Brother MFC5440CN - Yellow cartridge does not print despite being
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Jan 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Replacing Colour Cartridge
Most likely dirty connections. Try cleaning the print cartridge, and the contacts inside of the printer with a swab of alcohol. The cartridge, and printer need to communicate properly, and sometimes a fingerprint or ink can interfere. (Yes I know I don't spell very well, sorry)
Mar 19, 2008 | HP Photosmart 3310 Printer
Colour printing
Is by any chance a third party cartridge?
Jan 13, 2008 | Printers & Copiers
Canon imageCLASS D880 All-In-One Laser Printer Logo
270 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
