Question about Kitchen Ranges
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Posted on Jul 09, 2009
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Cleaning in between the glass on the doors
The door will have to be removed an taken apart. Be very careful l with any seals and gaskets possibly even insulation and take note of where all screws and various parts go so that it all goes back together properly.
Jan 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire Dble OVen Model FEB30T6DCC Stainless (electric
This exploded diagram of the door should help you get it apart, 4eb927f.gif It is going to be shrunk by the forum software, the full size image is
here http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=FEB30T6DCC&mfgModelNum=&fkMfgID=4
along with a full list of parts should you need them
Sep 23, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirt and grease between glass in oven door
My husband cleaned this today!! Yahoo--I had over sprayed the glass cleaner and it ran in the vents.
If you pull out the drawer on the bottom, and look up you will find that the glass is being held in at the bottom by a "clamp" & 3 screws, one on each end and in the middle.
After you remove these, the glass front will come off, and you will see the inner door. There is another piece of glass that I cleaned, and now it looks 100 % better. Of course, the door comes apart easier than it goes back together, we had a little trouble lining up the screws. Don;t push the glass on too tight, the screw holes lined up better when there was a little space.
Dec 04, 2007 | Kitchen Ranges
Kitchen Ranges Logo
347 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
