Question about Sony FD Trinitron WEGA KV-20FS100 20" TV
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start the TV it starts off... the colors are not super bright and the image is shifted about 5 inches to the right and after 10 or 15 seconds it automatically shuts off. what's the problem now?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Without voltage readings, it could be a number of faults in the horizontal section. If have not considered, possibilities are:
  • the FBT and/or the transistors was not an exact replacement or is a substitute;
  • the secondary output of the FBT is being overloaded;
  • H-osc & H-drive would have to be checked.
Unfortunately, due to unavailability of a schematic diagram I could not be more specific nor provide further information.
Good luck and thank you for asking FixYa.
Posted on Jul 01, 2009
  • 1,056 Answers
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Posted on Jun 27, 2009
REPLACEMENT FLYBACK TRANSFORMER SONY TRINITRON CRT TV KV-2062E IS REQUIRED
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sony Televison & Video
Number FBT
Hello
Number of Horizontal Output Transformer [ FBT OR LOT] for SONY FD TRINITRON KD-XBR960 is,
1-437-523-61
OK
Jan 24, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a sony vega 32" fd trinitron i turn it on and the screen is black in the right corner there is red light that says stand by timer. how do i get thr screen back on?
Ur high voltage is dead or dying.The FBT call the Fly Back Transformer is dead or dying.U can tries unplug the tv about an hour,might get the high voltage back temporally will happen again later.The big block of plastic with the red wire with a cap to ur CRT(tv tube).That ur prob.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Blinking red light 3 times on sony 34hs420
Ur high voltage transformer it dead.The big block of plastic with the red wire with a cap hook to the CRT(ur tv tube).It call the FBT,
the Flyback Transformer that thing it dead.
Sep 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron not working properly after FBT replaced...
the capacitors in horizontal circuit near the FBT . probably the HOT is damaged again due to the capacitors problem.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Technical repair questions
your fly back is bad. the fuzziness is caused by the bad fly back. and soon you will lose the picture due to this fly back and might cause the horizantel transister to blow. change it as soon as possible. good luck
May 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-20FS100 20" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
