Question about HP (D7580-60003) Motherboard
Usb ports no longer work...
I think I deleted accidently a microsoft program using the add/remove. Since then the usb ports no longer work. I've gone into the devise manager, using the troubleshooting, but still nothing. I tried uninstalling, updating...nothing. My system is windows xp. Any advise would be extremly appreciated. Thanks
Thanks for the advice. Still no go. Restore point not possible since the problem happened 10 days ago and it won't go back that far. Any other advice?
Posted on Jun 27, 2009
  • HP Master
  • 670 Answers
Have you tried a restore to an earlier date, choose a date on which the ports were still active. Click start, click all programs, click accessories, click system tools, click system restore, choose restore my computer to an earlier time, select date. You can also roll back drivers by clicking start, click control panel, click system, click hardware, click devise manager, click on universal serial bus controllers, rt click on your usb port if it is there and choose update driver. Good luck.
Www fixya com support
Search the web for a free program called Recuva. Download and install it on your computer. Plug your SD card into a card reader and connect it to a USB port on your computer. Run Recuva and follow the instructions to recovered the deleted pictures from the SD card. This will only work if the card has NOT been used since the pictures were deleted. If the card has been used, the deleted files may have been overwritten and they are gone.
I've used Recuva to find and recover pictures that I have deleted from my recycle bin when I emptied it. Try to download the program from the Recuva site since many of the download sites now try to slip stuff you won't want into their downloads. Be careful to uncheck any boxes that attempt to add automatically things like toolbars, search engines and other unwanted programs.
May 22, 2013 | Nikon D70s Digital Camera
No Connection
Hi Norm,
First, try a different USB device in the USB Ports, to make sure they are not disabled.
Uninstall the DWL-G120 Drivers, in the add/remove programs. Unplug the device. Download and install this program.
http://www.nirsoft.net/utils/usb_devices_view.html
Click on Options, check each one. Click on all instance of the USB device you want to remove, (Marked Disconnected.), and under File, click on Uninstall Selected devices You can hold the CTRL key to select more than one.
Once they are all cleared, Open My Computer and go to C drive. Delete any folders left over from the DWL-G120.
Reboot, and reinstall the drivers, and plug in the device.
If that don't work, you can try a different USB port for it.
Good Luck!
Jan 07, 2008 | Computers & Internet
How can i remove kvusb security from my epro 4gb flashdisk
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driver Click start click on my computer you should see your usb drive right click then select format. another way is to control panel administrive tools computer management disk management right Click on your drive select format hope this helps
Jan 01, 2013 | Electronics - Others
Installation
If you have deleted the program from your computer, you should be able to plug the Coby player (TURNED OFF) to the computer and re-install it.
If Coby Manager program is no longer on the Coby player (If you re-formatted the player), you can get a copy of the MANAGER here:
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
Don't let it throw you that it says it's for the MP822 - it also works great for the MP610
1. Install Coby Media Manager from download
2. Open Media Manager
3. Plug your COBY player (THAT IS TURNED OFF) into the USB port - it will show up in the "DEVICE" tab
Apr 03, 2010 | Coby MP-610 MP3 Player
I accidently deleted microsoft office
Uninstall the Microsoft Office from the Add Remove Program's then restart ur computer & install the Microsoft office again.
Nov 06, 2009 | Microsoft Office Standard for PC
HP PSC 1513 ALL IN ONE - NOT CONNECT WITH MY LOP TOP-FUJITSU SEIM
First remove the USB lead from the Laptop, then go to the control palel/printers and faxes and delete the printer if listed.
Than go to add/remove programmes and remove any HP software installed.
Reboot and reinstall drivers and software connect the printer when asked to by the install prog.
I'm presuming you have the correct drivers for your OS if not go here and download them
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=428801&
Sep 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
FlipShare software won't install
I had the same problem when plugging my Flip into the USB port. Kept saying a file was corrupted. I went to the Pure Digital Technologies website and downloaded the upgrade/program directly and it installed fine. You might try that if you already haven't.
Jun 12, 2009 | Pure Digital Flip Video Ultra Camcorder
My ML-2510 samsung printer stopped printing?
Delete printer Icon in the "printers and faxes" dialog box, then use the software installation Cd to re-install it. Also, depending what software that printer uses, there may be a "Samsung" software to delete in "add/Remove programs" in the "control panel" as well. I would delete everything and start from scratch.
Select the proper port when setting up. I assume you are using a "USB" port?
Mar 15, 2009 | Samsung ML-2510 Laser Printer
I think this program was uninstalled by accident
in device manager
if you see the driver click to update or install
if you can't see it then in add hardware
click audio or sound
follow instructions a box may appear showing the device if so hight light and next if not then
choose option yes to automaticcally install
also you could shut down and remove audio card restart shutdown again reinstall card the startup again the add hardware should automatically install
but i would do this unless it was absolutely neccesary
Feb 21, 2009 | Dell Computers & Internet
Microsoft Camera software
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 08, 2007 | Microsoft LifeCam VX-3000 Web Camera
HP (D7580-60003) Motherboard Logo
75 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
