Question about RCA F32450 32" TV
Sound and picture distorted only on lower channels
I have a 17 year old rca set that has bad picture and sound quality on channels 2 thru 7...has been happening for the past 6 months or so. Stations higher usually look and sound ok. Have 3 tv's in house and this is only one I have a problem with.
  • 1,694 Answers
Bad tuner.......they are electronically divided in sections called
bandwidths, i.e. 2-6 , 7-13 so-on.........T.
Give accurate model # / service # for RCA part #............
Posted on Nov 09, 2007
I think it's the av channel but not sure
Make a reset to this set. Refer its user manual for details about how to do this.
Jun 03, 2012 | Symphonic WV806 DVD Player/VCR
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
Distorted picture that curves up at the bottom of the screen
My 9 years old Mitsubishi WS-55857 had the same problem (distorted pictures) for couple of months and I was about to buy a new plasma TV. But, I found and I decided to give a try before buying a new TV. I received a convergence repair kit in two days with web site info for detailed instructions with many picutres to explain the process. When I had questions and Ed was very prompt to answer my questions thru the e-mail. I never done solding before, but I am moderate handy person. I spent less than $100 and three hours and my TV picutre looks stunning. I went thru advanced convergence process after I repalced the convergence chips and replaced RCA video cable with better quality and my TV picture looks as good as brand new. Thansk ED for your help! From Portland Oregon
Feb 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Picture quality
Which channels? Tuners are divided into bandwidths-----
2-6 is V low, 7-13 is V high and so on.If say, 2-6 acts up, but
7 thru 13 never does,then the tuner is bad.
This solution assumes that video inputs were ok......T.
Oct 24, 2007 | Toshiba 53AX61 53" Rear Projection...
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Only receiving Channels 50 and above; no lower channels
It could be anything from corrupted data in the EEPROM (a memory IC that stores all the channel information and picture settings) which is usually caused by bad ground solder connections inside the tuner itself which is built into the main circuit board and would have to be repaired, not replaced or components inside the tuner section of the main PCB. With that being said - if you have to get a technican to come to the house and repair the set then it would probably be best to buy a new HDTV set. If you can take it to a repair shop capable of fixing the tuner, it could cost close to $200 to repair is my guess, and may work OK for another year or two before the picture tube finally wears out.
Dec 28, 2006 | RCA F35673MB 35" TV
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
RCA F32450 32" TV Logo
87 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
